Question about Bosch Drills
Bosch battery charger al15fc2498 fault does not charge
Does not charge
4 Suggested Answers
hawk127311
  • 350 Answers
SOURCE: dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
  • 885 Answers
SOURCE: I have a Makita with 2 PA14 batteries and a
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Posted on Aug 19, 2010
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
Can't charge the batteries on my Bosch jig saw. What to do?
the batteries are dead because of no charge for a long time
chears
Jan 31, 2017 | Bosch Saws
Bosch PSR 1440 power drill. How do I know when the battery is charged?
Tracey,
There should be a legend on the top of front of your charger that should explain the light sequence for the charging process.
May 15, 2015 | Bosch Drills
You cannot over charge a battery pack as the charger stops at full charge. However by recharging a partially used battery pack you can develop a memory in the pack that the charger will not charge past
Jul 06, 2013 | Drills
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
Have a fault with a bosch battery chaRGER 1617224006. The charge red LED doen't come on
Open up the charger and remove the bad LED. Then re-solder a new LED on. LEDs are fairly cheap and you can get one at Radio Shack or similar electronics store in your area. Alternatively, you can just call the manufacturer and have them deal with it if your still under the 1 year standard warranty. Take the thing back to the store and exchange it if your under the 30-60 day warranty most stores give you.
Nov 02, 2010 | Bosch Drills
Nov 10, 2009 | Bosch Drills
36 volt battery won't charge
Get a voltmeter and check for the output voltage of the charger. Should be greater than 36 volts. Also make sure that the voltage is getting to the battery via connectors. Just be careful around lithium batteries - they can blow up of short circuited!!!!!
Sep 14, 2017 | Office Equipment & Supplies
Drills Logo
654 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
