Question about Diesel Garden
Front wheel bearings - Diesel Garden
    Sergeant:
  • 316 Answers
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you.
Posted on Feb 18, 2012
How do I replace a front wheel bearing?
front wheel bearing is pressed into hub and has retaining clip on rear and then cv axle shaft comes through center and has a nut and keeper pin. Rule of thumb is to replace both front wheel bearings at same time. raise front of vehicle place on jackstands for safety remove front wheels remove brake calipers remove front rotors and cv axles remove steering hub assy from lower ball joint,tie rod end and struts take hub to shop and have bearing pressed out have new bearings pressed in reassemble front wheels in reverse order of disassembly.
Aug 03, 2014 | 2002 Mitsubishi Lancer
How do you adjust the rear wheel bearing?
Rear wheel bearings on front wheel drive vans are much like front wheel bearings before front wheel drive.
You have an inner and outer bearing with a nut and lock washer.
After the bearings are packed with grease, you tighten down the axle nut until snug then back it off a notch. Then put the lock washer or lock ring on. Some have a cotter pin to hold the nut in place.
The wheel should spin with no drag from the bearings.
Jul 07, 2012 | 1993 Plymouth Voyager
Front wheel assembly diagram
For front wheel assembly diagram and replacement,click the link below and go through procedure:----Front wheel hub assembly Diagram and replacing procedure? http://howtobyme.blogspot.in/2012/02/front-wheel-hub-assembly-diagram-and.html
----------Front wheel assembly diagram to replace wheel bearing? http://howtobyme.blogspot.in/2012/02/front-wheel-assembly-diagram-to-replace.html
-------------How to replace Front wheel bearing? http://howtobyme.blogspot.in/2012/02/how-to-replace-front-wheel-bearing.html
-----------Check all 3 links one by one.This will help.Thanks.
Feb 22, 2012 | Ford F-250 Cars & Trucks
Mazda mpv 2006 repack wheel bearing
There is a little difference between the front and rear. The days of packing wheel bearing is almost over. The front bearing you have to pull the hub and change to bearing. The rear wheel you have to change out the hub bearing and all. The front is a sealed bearing and not serviceable. Please rate my answer so I am rewarded points for it.
Jan 29, 2012 | Mazda Cars & Trucks
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
I am trying to get the wheel assembly apart to change the front bearings on a 1996 mercury villiger
http://groups.yahoo.com/group/villagerquest/
Item Part Number Description 1 — Cotter Pin 2 — Nut Retainer 3 1131 Insulator 4 3B477 Front Axle Wheel Hub Retainer 5 1195 Front Wheel Outer Bearing Retainer Washer 6 1104 Wheel Hub 7 1107 Lug Bolt 8 3K050 Snap Ring 9 3123 Front Wheel Bearing 10 2K004 Front Disc Brake Rotor Shield 11 3130 Front Wheel Knuckle
Wheel Hub, Wheel Knuckle and Wheel Bearing SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Tie Rod End Separator T85M-3395-A
Removal
  1. Raise and support the vehicle.
  2. Remove the wheel (1007) and tire assembly.
  3. NOTE: It is not necessary to disconnect the front brake hose (2078).
    Remove the disc brake caliper (2B120) and suspend it with mechanic's wire out of the way. Refer to Section 06-03 for the removal procedure.
  4. Remove the front disc brake rotor (1125).
  5. Remove and discard the cotter pin.
  6. Remove the nut retainer and insulator.
  7. Remove the front axle wheel hub retainer (3B477) and the front wheel outer bearing retainer washer (1195).
  8. Remove and discard the cotter pin from the front suspension lower arm ball joint (3050).
  9. Loosen the front suspension lower arm ball joint nut until it contacts the front wheel driveshaft joint.
  10. Strike the front wheel knuckle with a hammer while pulling down on the front suspension lower arm (3078) until the front suspension lower arm ball joint separates from the front wheel knuckle.
  11. Remove the front suspension lower arm ball joint nut.
  12. Remove the front suspension lower arm ball joint from the front wheel knuckle.
  13. Remove and discard the cotter pin.
  14. Remove the tie rod end nut.
  15. Use Tie Rod End Separator T85M-3395-A to separate the tie rod end (3A130) from the front wheel knuckle.
  16. Remove the front brake anti-lock sensor bolt.
  17. Remove the two front shock absorber-to-front wheel knuckle nuts.
  18. Remove the two front shock absorber-to-front wheel knuckle bolts.
  19. Remove the front shock absorber (18124) from the front wheel knuckle.
  20. Use 2-Jaw Puller D80L-1002-L, or equivalent, to separate the front wheel driveshaft and joint (3B436) from the front wheel knuckle.
  21. Remove the front wheel hub, front wheel knuckle and front wheel bearing as an assembly from the vehicle.
  22. If necessary, match mark and remove the steering stop bolt and steering stop bolt jam nut from the front wheel knuckle.
Installation
  1. Position the front wheel hub, front wheel knuckle and front wheel bearing as an assembly on the front wheel driveshaft and joint.
  1. Install the front wheel knuckle into the front shock absorber.
  1. Install the two front shock absorber-to-front wheel knuckle bolts.
  1. Install the two front shock absorber-to-front wheel knuckle nuts. Tighten the front shock absorber-to-front wheel knuckle nuts to 113-123 Nm (83-91 lb-ft).
Apr 10, 2009 | 1996 Mercury Villager
Noise in front end, sounds like wheel bearings, 110,000 miles, rear end axles and bearings replaced, sounds still present, louder when making left turn when weight of vehicle shifts to front end right side
You say the rear wheel axles and bearings have been replaced, you mention nothing of the front wheels, you have the symptoms of a front wheel bearing being worn out, remove them and check for pitting in the bearing rollers or the bearing races, I am sure you will find a problem. Hope this helps solve your issue with the bearing noise.
Jul 26, 2008 | 2004 Ford Crown Victoria
Garden Logo
26 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Wade Mobley
Wade Mobley
Are you a Diesel Garden Expert? Answer questions, earn points and help others
