Question about Furuno 1623 Radar 16nm Range
Ca I buy a 5 metre extension cable as the 10 metre cable that came with the 1623 is too short?
    Problem Solver:
  • 7 Answers
Quite sorry but Furuno does not carry "extension" cables for radar antenna signal cables. If the original cable is too short, you would need to obtain a 15M whole cable, furuno part number 001-122-870-10. Or the 20M whole cable part number 000-144-565. You might be able to find a technician willing to custom manufacture an extension for you but I emphasize the word might.
Regards,
John
Posted on Feb 21, 2012
How can I extend the hose so I don't have to bend so far down when I vacuum. I am tall
You could try wearing the cleaner like a backpack...
I live in a small town and there are at least two businesses here where I could buy vacuum cleaner hose by the metre.
I have also seen purpose-made 1 metre hose extensions.
It isn't always easy but I have repaired and replaced hoses, changed ends and generally managed to use surplus and discarded hoses rather than buy new.
I suggest you approach the sort of business that supplies vacuum cleaners and washers and suchlike to other businesses rather than a high street type shop.
Feb 25, 2015 | Miele Olympus S2120 Canister Vacuum...
Speedometer is not working on my car
*Check the 2nd end of the cable connected to engine.. move the cable end clockwise and check if the metre is moving. If yes then there is geyor inside the engine area where the 2nd end is connected. you've to replace the geyor.*Check the connection of metre cable with metre... you have to remove metre console.
if its ok then you have to replace the cable.
otherwise you've to repair the metre
Aug 19, 2012 | 1992 Toyota Tercel
I Have a Samsung handy & easy Hi 8 NTSC SCL901 camcorder and i want to know if there is a cord that i can buy to put what i recorded on my computer?
You need this cable or one that is labelled as USB to Mini USB.
http://www.amazon.co.uk/AmazonBasics--Male-Mini-B-Cable-Meters/dp/B001TH7GUK/ref=sr_1_1?ie=UTF8&qid=1307984144&sr=8-1
http://www.play.com/Electronics/Electronics/4-/5889160/USB-2-0-5-Pin-Mini-B-Cable-1-8-Metres/Product.html?searchtype=allproducts&searchsource=0&searchstring=mini+usb&urlrefer=search
Jun 13, 2011 | Samsung SCL901 Hi8mm Camcorder
Sensor bar cable too short. can we buy an extension cable
probably yes you can..but make sure that you buy appropriate extension cable/wire..
Apr 22, 2011 | Garden
Hello i have a Fusion en at 110 amp speaker base and the flat wire from this unit to a volume control box is damaged. i would like to buy this cable, it is black , flat has 6 wires and each end has a...
RJ12 6P6C to RJ12 6P6C Cross Over Cable Plug (RJ11 6 wire) BLACK 3m The cable you need is above you will probs need a 5 metre cable if it's in your boot they cost about 3 to 5 pounds online.
Dec 18, 2017 | Fusion FEW12PK Car Subwoofer
CONVERT 5 CUBIC METRES TO TONNES
Cubic metre is a measure of volume. Tonne is a measure of weight (or mass). The weight of 5 cubic metres of something depends on the density of that something.
5 cubic metres of air weighs a fraction of a tonne. 5 cubic metres of water weighs 5 tonnes. 5 cubic metres of lead weighs about 56 tonnes.
Feb 04, 2011 | Canon P23-DHV Calculator
Where to buy a XLR cable extension in Fremont ca required for a Peavey XLR560 power mixer
You can buy them at Radioshack.
39106 Fremont Hub
(between Argonaut Way & Mowry Ave)
Regards,
Gerard
Mar 19, 2010 | Peavey Monster Studio Pro 1000 XLR-XLR Mic...
Is it a good idea to use fire wire 400 over 100 feet? do you get deminished signal at the other end?
The limit on firewire 400 is 16 feet (5 metres). You can buy firewire repeaters but you would need several. Firewire 800 is ok for 32 feet / 10 metres which means that less repeaters would be needed. However in both cases an optical repeater can be used for up to 3200 feet!! (1000 metres) for 400mbps or 1600 feet (500 metres) for 800mbps.
Nov 08, 2009 | Datavideo Upgrade Cards for DataVideo...
Mousepen 8x6 cord USB extension cable?
$6.50 on amazon for a 10' extension. You may even find it at best buy, you can hook multiple extensions together.
Jun 12, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Furuno 1623 Radar 16nm Range Logo
216 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
