Question about Dryers
Kenmore 70 series electric dryer
Im having problems with my kenmore 70 series dryer not heating up. Does anyone have any tips on how i can fix it??
    Genius:
  • 1,122 Answers
Do you get any heat at all? is the drum turning? if yes and yes you need to check the dryer hose all wall hole to see if it is clogged,clean both out and see if this helps,if no heat the main heater fuse might be bad,check that also,hope this helps you-mike
Posted on Oct 26, 2008
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
I have a Kenmore series 70 dryer that runs but does not put out any heat. What part(s) do I need to fix this?
heatman101
Jun 29, 2011 | Kenmore Dryers
I have a Electric Kenmore Dryer 70 series. No heat and timer doesnt work.
heatman101
Mar 28, 2011 | Kenmore 700 6972 Dryer
My Kenmore electric dreyer does not heat? Vent is not clogged and blowing out freely. I have replaced the thermal Fuse, and the Multi temp switch kit and still no heat? The model No. is : 96573220 Kenmore...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Kenmore Dryers
Just purchased a kenmore 70 series gas dryer turns on but wont heat up
heatman101
Sep 19, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
The dryer won't light 70 series Kenmore (gas)
heatman101
Aug 08, 2010 | Kenmore 700 6972 Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Dryers Logo
266 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
