Question about Motorola Mobility DROID 2 Cell Phone
How do I pair lg hbm230 Bluetooth to my droid
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Hi, i need to know how i can pair my bluetooth plantonics explorer 232 to my incrediable droid 2? when i scan to look for the bluetooth device my phone couldnt find/pair it...please help!
The Bluetooth device that your Droid 2 is scanning for must be in "Discoverable" mode:
1. (If not already off) Turn it off by pressing and holding the call control button. Hold it until the indicator glows red and emits a sound.
2. Now press and hold the call control button for five seconds until the light begins blinking red and blue, then release the call button.
3. You may now rescan for your Explorer 232 on your Droid 2 and Select it when it shows.
4. Enter "0000" as the passkey if you are prompted for one.
Sep 25, 2011 | Plantronics Explorer 232 Bluetooth Headset
Had lost my Plantronics 220 for a year. am trying to pair with my Droid. can't remember how to do this. don't have any paperwork with me right now. what do I need to do? simple instuctions for a...
To find the User's Guide, check here: http://www.plantronics.com/us/support/docs/index.jsp?prodId=prod5920006
On Page 4 and 5 it details how to Pair the Bluetooth device to your phone.
For an Android 2.2 phone:
  1. Turn Bluetooth Headset on according to instructions in the Users Manual
  2. On phone, Go to Applications --> Settings--> Wireless and Network --> Bluetooth Settings
  3. From this menu you can turn Bluetooth on and once its on you can choose to Scan Devices
  4. Select your headset from the list.
  5. You will be prompted to enter a PIN or Code. By default it is 0000 (4-zeros)
  6. You devices should now be paired.
Hope this helps.
May 12, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a droid x and i cant listen to voice messages or music thru my blue tooth... any suggestions.
Check your bluetooth and make sure that it is capable of playing music through the headset. I had a Motorola Bluetooth headset that was unable to play music through it, but I later then upgraded to a Plantronics headset, and this played music just fine.
http://www.plantronics.com/us/product/voyager-pro
As for not being able to hear voice messages through your bluetooth headset, make sure that the volumes are up on both the device and the headset, and try deleting the paired device and re-pairing it!
Feb 25, 2011 | Motorola Mobility Droid X
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I sync my motorola H710 bluetooth with my Motorola Droid?
Here's the instruction manual for the H710:
Motorola H710 download instruction manual .pdf 2MB
You'll have to check your owners manual for your Droid, but it's probably under Settings > Connections > Bluetooth (Turn on) > Discover (Pairing code 0000)
Feb 04, 2010 | Motorola Mobility H710 Bluetooth Headset
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Dec 20, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
Motorola Mobility DROID 2 Cell Phone Logo
953 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
