Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Display blank My clock and temperature display gradually got dim and is now completely blank. Can you tell me if the display needs replacing or could it be another cause. Thanks.
  • 10 more comments
  • Patrol12 Nov 05, 2007
    Mine is starting to experience the same thing. The clock is very light and the temperature display is barely visible. Have just started troubleshooting with no progress so far.
  • baking mom Nov 08, 2007
    My temp doesn't show up at all and the clock is barely visible. Is there a recall on it since there are a few people with the same problem.
  • Anonymous Nov 17, 2007
    Everything is so dim, I can't read anything anymore.
  • Anonymous Dec 10, 2007
    Oven clock started to lose time and now there is no display at all. Have reset all circuit breakers to no avail. Any suggestions?
  • BigCheese Dec 29, 2007
    Would not expect a clock display to ever fail. three months ago ours started to dim and is getting dimmer by the day. Appreciate knowing fix other than replacing whole unit.
  • Mark33 Jan 10, 2008
    I have had the same problem but have this question.. How do you get the part and how do you know how to replace it?? I took the panel off lastnight to see if it was simply a fuse or something.. I have had the manual sent to me, I have called Jenn Air and they are NO HELP whatsoever.. Oven works great but the digital readout has simply faded away.. HELP!!!!
  • Anonymous Feb 28, 2008
    Our double electric Jenn-Air convection oven display is going dim. Trying to find source of problem. I bake quite a lot-this sucks.
  • rebrady Mar 11, 2008
    Display went dim but have seen it brighten for short period. what now???
  • NilsF May 11, 2008
    Dim Display,and getting dimmer...help
  • NLF1 Jun 04, 2008
    Have had same problem. Oven works, but I can't see what I'm entering, or the oven temp., etc. anymore. My friend has the same problem with her oven. Do we need to get new electronic clock controls at over $150 for parts alone??
  • Richauds Aug 05, 2008
    Looks like ours is doing the same Model JJW9530CAAW - can't read the serial #, as it's blocked by a mounting strip. We've had it six years, so I'm assuming it's an out of pocket expense!
    Mickey
  • mcward7 Oct 22, 2008
    We bought our house a year ago and the oven came with it, it is a great oven, but it the clock and temp recently started fading. Where do I get this panel to fix it and is this something I should be doing or does it really require a professional?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
The unit is easy to replace but is there a way to tell if it is the light unit or the power supply unit? I have and can not get any wiring diagram to see what the voltage is supposed to be.
Posted on Dec 01, 2007
  • 175 Answers
Every time I have seen this problem, it has been a bad display assembly. These are fairly easy to change yourself, but the part is kind of expensive, I think in the $150-$200 range. Hope this helps!
Posted on Nov 05, 2006
I talked to Jenn Air and they did state a reason that seems reasonable. It is not the display assembley that is the problem but the design. The HEAT causes the display assembley to malfunction. Jenn-Air has added a cooling fan between the baking area and the display assembley in the newer models. You may have to keep replacing the display assembley about every two years if use the oven a lot in the older models. Yuck!
Posted on Apr 29, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Jul 13, 2010 | Whirlpool RBD305PD Electric Double Oven
Hi i have a de-dietrich dod338 oven but ive found the light on the clock is very dim yet if i have a power cut and when i reset the power trip again its bright but as soon as i try to set the time it goes...
i had this problem also - it is the timer assembly. you can replace the timer assembly as a whole, or if you're useful with a soldering iron, replace the capacitor which is right next to the digital display. the display gets warm and this gradually breaks the capacitor. I replaced this - it was about £3 from rs components (the capacitance and other info is printed on the side of the capacitor). Hope this helps - i bought a replacement main board and clock assembly ( which got lost in the post so i tried to fix it in the mean-time while the replacement was sent out.) obviously don't do this fix if you are not confident, but that was the fix for my problem which is the same symptoms as yours.
Dec 14, 2009 | Ovens
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Display blank
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Ovens
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
516 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
