My speedometer is not working in my 93 Geo Prism. I replaced the VSS but still not working. Can only find a speedometer cluster for a 95 in my area. Will this fit in a 93?
If in some days, you realize that you don't want to use Gmail anymore, but you also don't want to lose your frequently contacted email addresses,you can export contacts in Gmail to transfer to your new email service. You're also able to apply this trick to backup the email addresses that you frequently contact with in case Gmail down.
In this article, I will introduce you on how to export and backup contacts in Gmail as well as export contacts in Gmail to other Gmail accounts, Outlook account or another email.
Step 1: In the Gmail web interface, click on the down - arrow next to the Gmail item (on the top left) and choose Contacts.
Step 2: Choose More-> Export in the Menu on the left.
Step 3: Click on Go to old contacts
Step 4: Click on Others item on the taskbar then choose Export...
Step 5: Choose the contact list that you want to export. Here, I will choose All contacts to export all of my contacts.
And select which formats you want to export. If you want to backup your Contacts or import it into another Gmail address, then you select option 1. Select option 2 if you want to use Outlook or Hotmail and the 3rdone if you use email service of Apple.
After having selected, click on Export.
Step 6: Now, CSV file will be downloaded to your computer.
Step 5 : You can use this file to add your contacts following the option you select in.
Tag: gmail login, gmail log out, gmail, gmail sign out, gmail sign up, gmail sign in
Gmail Sign up Create New Gmail Account Gmail Sign up
No it will not.Bit of modification is needed.95 is newer and 93 is older.Its not impossible,but will need some RnD -------- For
speedometer related issues, the help links are provided below. Click the link
below to go through its details: ---- How to trouble shoot speedometer? http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html ----------- http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html --------- http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html -------------- http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html ----------- http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html --------- --------------- http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html -------------- http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html -------- This will help. Thanks
why speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
Warning lights on and
speedometer died?
ABS & Brake lights
warning indicator steady on dash and speedometer not working?
Vehicles Cluster panel Not
reading Miles?
Odometer works properly but speedometer works
intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
Speedometer not working on Ford?
SOURCE: SPEEDOMETER CABLE NEEDS TO BE REPLACED
There is no cable on the 93 Prizms. The problem is one of two things, either the "vehicle speed sensor" or the instrument cluster itself. I also have a 93, and the speedometer started acting up a while ago. Sometimes it would register 0 then it would spike up to 70 and stay there at highway speeds then back to 0 upon slowing. I replaced both items from the junk yard. The speed sensor at an auto parts store will run about $160, and a new cluster will cost A LOT more at the dealer! I first replaced the speed sensor with no luck ($5.00 at the junkyard) the same thing happened 0 or 70. I replaced the cluster today ($13.99 at the junkyard). That was it! Problem solved. The cluster is EASY to replace, remove the 2 screws from the trim piece and remove trim. Next, remove the 4 screws that hold the cluster in place; 2 at the very top (don't remove the ones just above the cover glass) and two at the bottom. Pull one side of the cluster out; there are 3 plugs; squeeze the center of the plugs to release the clip and wiggle them free. Connect the replacement cluster, but before screwing it in, do a check to make sure all the panel lights work. I had a few that were burned out, so I used the old cluster lights to replace them. I would try replacing the cluster first. Good luck!
SOURCE: I HAVE A 1994 GEO PRISM 1.6L THE SPEEDOMETER
I've had a similar problem with my '94 prizm. I had to replace the instrument cluster about seven or eight years ago because the speedometer quit working. After replacing with a used instrument cluster it's been working fine till now. However, the problem is back again....so I'm looking for another used one. There is definately a weakness in this speedometer design when the mileage on the car gets high. Your problem is different since you replaced both the sensor and the speedometer and it still doesn't work. Chances are, you got a speedometer that didn't work to begin with. I would try another used one.
