Question about Cub Cadet Garden
Will not start
Possible selinoid
    Sergeant:
  • 316 Answers
Hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Posted on Feb 18, 2012
Toro lawn tractor starting problem
both of the small wires to the solenoid go threw safety switches start with the one on the clutch/brake pedal
Jun 09, 2012 | Garden
My craftsman table saw will not run.
That is the selinoid..it needs replaced..if it is not under warranty ...buying a new motor from Harbor Freight would be best ..I did this my self this year..Craftsman could not replace the selinoid on mine so that was my fix
May 24, 2012 | Craftsman Table Saw
Turning key doesnt power up dash on my 1982 928 when it worked fine this morning .starter wont engage or even go click, the headlights wont pop up. the key seems sloppy in the ignition however it has...
hello ther
Are the lights on the dash on or not?
if yes check your grounds what you can find.Mainly at the battery.It could also be the electrical part of your ignition switch,
let me know
proporsche@yahoo.com
proporsche
Apr 30, 2011 | Porsche 928 Cars & Trucks
For about 2 weeks my car has been hard to start now it wont start it acts like the starter is not engaging to turn motor over when you try to start it it makes a whinning spinning noise we took starter off...
sounds like the battery wire to the starter is possibly the culprit, it may have a bad spot in it not allowing enough voltage to the starter. also depending on the brand solenoid you purchased it is possible to get a bad one. i recommend borg warner electrical products. i hope this helps.
Feb 13, 2011 | 1994 Lincoln Continental
Turn ignition to start and all of a sudden car wont start or even attempt to start. Battery is good all starting cables are clean and tight. Then after I go through everything it just eventually starts...
Possibly the anti-theft system? Is the light blinking fast when it doesn't start? maybe the shifter interlock--does shifting to neutral make it work? Solenoid is possibility but not usually intermittent. Ignition is another possibility. Let us know as your troubleshoot and have more questions.
Sep 22, 2010 | Oldsmobile Intrigue Cars & Trucks
Water will not drain from dishwasher
the selinoid that activates the drain cycle is possibly burnt out. This selinoid is activated by the timer on the dishwasher. Before I changed out the timer I would change this selinoid. It is located right beside the motor. Take the model and serial numbers to a local appliance supply and they should be able to help you. The replacement of this selinoid is simple and self explainitory.., Good luck on your repairs hope this helped you some
Dave
Nov 09, 2009 | Kitchen Ranges
1992 toyota corolla merino 4a-ge engine. just stopped running while driving and won't start again. have replaced almost all electric components and still nothing. at ignition starter seems to spin but not...
get a new starter or starter selinoid, sounds like its hanging up possible stripped gear on starter of flywheel. If its a stick shift you can always put key in "run" position and have a couple friends push you in neutrel then when you gain speed put it in 3 gear and dump the clutch, if it starts you know the starter, selinoid, or flywheel is faulty
Jul 12, 2009 | Toyota Corolla Cars & Trucks
How to change starter selinoid
the starter selinoid is on the starter itself. normally a parts dealer will never seel you a starter selinoid individually but they will sell the starter with the selinoid. but you cant change the selinoid without changing the starter
Jul 09, 2009 | 1997 Chevrolet Camaro
1982 olds wont start i can jump it across the selinoid and it starts but when i remove jumper wire it dies
have you replaced the selinoid? It sounds like the 12 volts is not staying constant to the other side without the wire
Mar 05, 2009 | 1992 Oldsmobile Ninety Eight Regency
No water coming into dishwasher
The hum is a selinoid. The water inlet valve is selinoided operated so I woudl sspeculate that either the valve is bad or the selinoid is. You can check the selinoind with an ohm meter. Since it hums I am guessng that the valve is bad. Likely they come together as one unit.
Dec 28, 2008 | Bosch Dishwashers
Garden Logo
222 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
