Question about Mr. Coffee Bvmcejx33
Mr coffee thermostat bvmc-ejx33
Heating element
4 Suggested Answers
1800PartsFix
  • 36 Answers
SOURCE: BVMC-PSTX91 MR COFFEE....ONLY USED ABOUT 15 TIMES
Mr.Coffee guarantees their machines for one year from the date of purchase. If you still have a receipt I would contact them. If not there could be a problem with the board on the inside of the machine. Which, unfortunately, is not available yet to purchase so your machine can be fixed.
Posted on Nov 12, 2010
SOURCE: mr coffee vbx23 coffee pot looks like a two
Mike: I have the same problem. I measured the resistance, and they are open, infinite resistance. I soldered a heavy brass wire across them to bypass them. Pot works fine. I turned it on, no smoke no excess heating of the wire. Made a pot of coffee, waited the required two hours and it turned itself off as is supposed. Replaced the bottom held on by several Phillips-head self tapping screws. Have no idea why the "resistors" were even there. Could it be they are capacitors? I doubt that. Capacitors short and resistors open, if the capacitors were shorted they would stll pass current to the heating element. Seems to me they have to be resistors. Roy
Posted on Feb 06, 2011
mc1bean
  • 3053 Answers
SOURCE: Mr. Coffee BVMC-ZH1B Power Serve 12-Cup
Hello, yvonne
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
How do I clean Mr. Coffe, Model BVMC-PSTX91. I lost the manual that came with a little pkg of to make a solution for cleaning. Please advise. Thank you
I use a quarter cup of white vinegar and the rest water. do it just like making coffee but don't put grounds in it. then run several pots of water through to rinse it out.
Sep 28, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
Why won't my coffee single serve brew after cleaning?
You could try what this guy did with his http://www.youtube.com/watch?v=BWP_vn4uHew
Aug 07, 2014 | Mr. Coffee Coffee Makers & Espresso...
Why does hot plate for pot will not heat-up/mr coffee BVMC-EJX36?
No heat means either the heater element is "Open" or one of the 3 thermostats in Series with the Heater element is open.
you will need a Multimeter to measure... you will also need a phillips screwdriver and a Security torx bit to take the bottom cover off..
From there "CAREFULLY" put your meter on AC volts, and measure across the element... one side of the element has a white wire and the other side is going to one of the in-line thermistors... if you read 120 ish volts, then the element is shot... If it doesnt read anything, then keep one lead on the white wire while you trace back to the next thermistor for 120, then again trace back to the final thermistor... which is thermally connected to the element, that's the final one. If you still have no 120 volt, then the logic circuit is not firing the Relay on the PCB.
I know this because I've serviced one with a bad element... canot find a replacement part so far....
Jun 08, 2014 | Mr. Coffee Bvmcejx36
My Mr. Coffee BVMC-KG5-00 is not brewing
try going to Mr. Coffee and ask. All you need to do is clean the jet with a paper clip! yeeesh!!! <http://www.mrcoffee.com/service-%26-support/product-support/product-faqs/single-cup-%28brewers%29/bvmc-kg5/BVMC-KG5-faqs.html>
Mar 13, 2013 | Coffee Makers & Espresso Machines
Mr. Coffee BVMC-KG5 made cold coffee
It may be the heating element or thermostat is bad. Try cleaning the heating element and removing any debris.
Download Mr Coffee BVMC KG5 Manual
Feb 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
Coffee brews to cold
Try doing a full descale treatment, if the heating element is covered with scale it won't heat properly.
If it is not thet it is a faulty thermostat or element.
Jan 29, 2009 | Mr. Coffee ECM21 Espresso & Coffee Maker
Mr. Coffee Bvmcejx33 Logo
170 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
