Question about Honeywell Programmable Thermostat Heater
How can I turn off adaptive intelligent recovery on th6320r thermostat
TH6320R honeywell thermostat
4 Suggested Answers
SOURCE: honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Posted on Feb 07, 2008
SOURCE: Honeywell T2060 UtilityPro Demand Control Thermostat
The user manuals don't show all the codes that the thermostat has....
If you can find an installer manual for this thermostat, or a similar one, it will provide the installer-only codes. Search for 69-1894ES.pdf - I think you want code 0530, and set it to 0. You access the installer codes by pressing two buttons - the ones each side of the centre button that you press for the user codes
Posted on Dec 04, 2010
  • 48 Answers
SOURCE: I want to turn off
You only need to turn it off if you are using program mode. Very nice stat btw. Heres a link to the pdf and I will also explain. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1896EF.pdf Use the system select button so that the heat option is flashing. Look at the bottom of the screen and you will see 7 boxes. First one done and seventh one cancel with all boxes in between blank. Now at the same time hold the 3rd and 5th box (buttons) for approx 5 sec. A new screen will appear with a number sytem staring at 0120 with up or down arrows and 20 with up or down arrows. Push the left up arrow till the left number reads 0530. The right number will read 1 if its on. To turn it off select the down arrow so it reads 0. Then select done and your all set.
Posted on Feb 26, 2011
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
I want to turn off the adaptive intelligent recovery feature on my TH8000 Series programmable Honeywell thermostat. How do I do that?
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 16, 2010 | Honeywell Electronic Programmable...
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Chromotherm 1V plus how to put intoAdaptive Intelligent Recovery
I finally found an installation guide online for this t'staat. All I had t do was go into installers mode on the controller and change a value from "0" to "1". It told me which buttons to push to get into installers mode and which item # to change. In my case it was item number 13.
Jan 16, 2009 | Honeywell Electronic Programmable...
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Honeywell deluxe programmable thermostat 69-1402m
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
