Question about Hotpoint Aquarius WMA42 Front Load Washer
Goes straigt to spin
My washing machine has suddenly gone into fast spin mode for a couple of seconds and then stops. It is not turning during the washing cycle but as soon as it drains it tries to go into a fast spin. I have changed the motor brushes, checked the pump and have cleaned out the debris trap. I have had all the connectors off and reconnected them. Can anyone help.
Anyone got a wiring diagram for the Aquarius Extra Model WMA48.
Posted on Jan 13, 2008
  • 139 Answers
TRY CHECKING THE BOARD ON THIS MACHINE ESPECIALLY THE MOTOR CONNECTION. WHAT YOU WILL AHVE TO DO IS PUT THE DIAL IN TO THE OFF POSITION ( ONLY AS GUIDE ) THEN DISMATLE THE BOARD FROM THE FRONT FACIA. HAVE A GOOD LOOK AT THE MOTOR PLUG CONNECTION SECTION OF THE BOARD CHECK TO SEE IF THERE ARE ANY TRACKS THAT HAVE BLOWN. I RECONDTION WMA ALL DAY EVERYDAY AND I HAVE HAD THIS PROBLEM BEFORE ONCE AND AM THINKING YEH THAT WAS THE PROBLEM. OR IT COULD BE THE TACO ON THE END OF THE MOTOR BUT THIS IS VERY RARE FOR HOTPOINT WMA UNLIKE THE HOOVER MACHINES.
Posted on Aug 31, 2006
SOURCE:
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
The cycle selector knob turns very fast and the wash goes from the fill mode to the drain mode and does not wash or spin.
the problem is with the selector.behind this,ther is a wheel with teeth.one of the teeth must be broken,causing the selector to turn too fast.
Nov 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer goes half way through wash and starts clicking. Motor will go into overload. When turned to manual spinn will click but spin slow. Switching to another cycle will sometimes start it working. In...
Barings probably over heating and expanding due to either dampness, lack of lube, bent broken or misaligned coupling. Is a warranty issue either way unless it was dropped during transit or used exessively on uneven surface. If its out of warranty you might be better of with a new one, trade in if possible.
Oct 31, 2009 | GE WBSE2090A Top Load Washer
GE Profile Washing Machine
There is a clutch which is mechanically engaged to stop the drum during agitation.
If the location pin is worn or bent it fails to engage and the machine tries to wash and spin at the same time.
Only solution is to call for a man who can fit a new clutch assy
May 25, 2009 | Washing Machines
Does Nothing During Spin Cycle than quits
You have a motor coupling gone.
Jan 25, 2009 | Washing Machines
My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
Oct 14, 2008 | GE WBSE2090A Top Load Washer
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
173 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
