Question about Paragon 1015-00RS Indoor Multi Operation Timer
Paragon timer part
The teeth have come off my dial for a paragon timer.
It is not working since it will not move without the teeth.
Model # P103-000
It also has another number on it D 1292-00
Where can I get a new dial for this timer
Thanks Debbie
  • Anonymous Jan 24, 2009
    I also have a P103 paragon timer and the dial teeth are stripped. Where can I get a new dial !!!
  • 52 Answers
Visit electricalexpeditors.com
we sell replacement parts
leave all info on the contact page
thank you
Posted on Jan 27, 2010
How to set the defrost duration on a timer
Copy following link for defrost timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
There are 2 general types defrost timers.
Time activated - Time terminated
Time activated - Temperature-pressure terminated, with timed termination back-up
Here is basic image:
http://waterheatertimer.org/images/8145-work-image.jpg
Rotate dial until current time lines up with pointer, insert tripper pin on outside edge of dial to select defrost start-time, move defrost duration tripper on inner dial to set termination time.
Each defrost timer is slightly different:
If timer is time-terminated, then wiring follows certain diagram.
If timer is temperature-pressure terminated, then different wiring diagram is used.
Nov 11, 2012 | Paragon 8145-20 Defrost Timer
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Moved time pointer on pool timer to set time than read instructions moved pointer back to original spot now timer does not click on or off when it passes pins
Timer brand and model number are not shown.
Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time.
Worn trippers can cause problem.
Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
Intermatic pool timers use set of 156T1978A trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Tork timers use P47 tripper on 24-hour clock dial
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
Paragon 4000 series uses X2772 tripper. Paragon timers are discontinued and trippers hard to find.
Open following links for different timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
Aug 01, 2011 | Hardware & Accessories
Apparently, the spring under the timer dial on my 4001 timer has been broken and the timer will no longer trip the trippers. Can this be fixed? It is a nearly-new unit and I like it.
Open following link for Paragon resources:
Individual parts are not sold except for X2772 tripper.
Move the manual override lever back and forth and see if load turns on-off.
Watch if on-and-off trippers are moving override lever back and forth, to see if problem is a worn tripper instead of broken spring.
Replacement 4001-00 timers are sold, even though Paragon is no longer making timers except defrost timers.
http://www.mdappliance.com/RBS-4001-00.html?mv_pc=00015
Replacement timer is Intermatic T101
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Jun 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
My model 1015-00RS timer comes on when it's set to be off at certain times, I push big dial down and it goes off, but then the next day it does the same thing, is there ajustment for fine tuning the...
I might not understand the problem correctly.
Open following link to identify timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
From your post, the large dial on your timer can be pushed up and down?
Or are the trippers popping up?
The dial is supposed to rotate clockwise during regular operation, and can be manually rotated either direction to set current time, but dial should not move in and out or up and down.
If the trippers are worn, then they are built in. The problem is that Paragon is no longer making parts and does not support 1015 timers.
It's possible the trippers might be getting pushed up if the on-off mechanism needs lubrication.
May 2011, Patriot stills sells the 1015-00RS for $187
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Intermatic 120Volt-480 Volt crossover product is T1975 (advantage is replaceable trippers, motor and switch)
Grainger sells T1975 for $126
http://www.grainger.com/Grainger/INTERMATIC-Indoor-Multi-Operation-Timer-6X761?cm_mmc=GoogleBase-_-Electrical-_-Timers-_-6X761&ci_src=14110944&ci_sku=6X761
Crossover wiring for 120Volt application:
All wires on Paragon 1 to Intermatic Clock
Paragon 2 to Intermatic Com
Paragon 5 to Intermatic NO
If there are wires on Paragon 6 to Intermatic NC
Upvote the help.
May 30, 2011 | Paragon 1015-00RS Indoor Multi Operation...
I have a Paragon 42013-20 timer, no longer manufactured. I need to find replacement trippers. Thanks for any assistance.
I cannot find a brochure showing specific paragon tripper numbers.
You have Paragon 42013-20 timer, DPST 10Amp 2Hp, Nema3 indoor-outdoor, 24 hour-timer with 48 trippers built into timer dial.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
If trippers are worn out, you can possibly work-around by rotating dial 12 hours so fresh trippers can be accessed using same dial. The only difference is nighttime hours shown on clock face will now represent daytime hours.
Intermatic Cross reference shows replacement timer is T1976R
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
http://www.intermatic.com/~/media/files/intermatic/catalog/pages/014.ashx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial%20with%20skipper.aspx
http://www.drillspot.com/products/648036/intermatic_t1976r_24_hour_electromechanical_timer
Difference between your paragon timer and suggested intermatic, it that Paragon throws both terminals at same time, while Intermatic has alternating NO NC terminals.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on timer or any do-it-yourself project.
Feb 23, 2011 | Paragon 42013-20 Timer
How temp. disable this timer, without loosing program
You posted under Paragon 42013-20 240Volt indoor-outdoor mechanical timer.
The 'program' is how you set pins on the dial.
Pins cause electrical switch to turn ON-OFF
http://waterheatertimer.org/pdf/Paragon-42000-sell-sheet.pdf
For example if you disconnect electricity to this unit.
Clock dial stops rotating, but pins are not changed.
When electricity is connected again, manually rotate clock dial until current time lines up with red pointer.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 | Paragon 42013-20 Timer
Pointer "B" was moved, contrary
The link above shows all the Paragon timers.
If you have the Paragon 4000 mechanical timer, then the pointer is at the 8:00 position.
To set current time, you lift and rotate white dial until current time lines up with the 8:00 position
If this is not your timer, then add a comment with your timer and model number and I'll look it up.
Nov 06, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
Paragon 1015-00RS Indoor Multi Operation Timer Logo
122 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
