DR-7580 missing wia drivers, win7 64bit - Office Equipment & Supplies
5 Suggested Answers
  • 6 Answers
SOURCE: canon dr-7580 scanner how to initialize cis
Hi, You may need to calibrate a new CIS with new Assembly. Later on this new assembly can be removed and your old one will do. Assembly means solonoid+ shading sheet. This will work for sure Samir Dhingra 9820800633
Posted on Jun 05, 2010
mohanchennai
  • 490 Answers
SOURCE: canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Posted on Nov 01, 2010
mohanchennai
  • 490 Answers
SOURCE: Hello, I am getting the following
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Posted on Feb 23, 2011
mohanchennai
  • 490 Answers
SOURCE: DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Posted on Dec 06, 2011
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
May 19, 2011 | Canon DR-7580
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
Nov 18, 2010 | Canon DR-7580
Canon dr 7580 erroe 32
If the main board (CPU PCB) not installed properly you get this error.
S. Mohan
Oct 11, 2010 | Canon DR-7580
Canon dr-7580 error 32
Oct 05, 2010 | Canon DR-7580
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Aug 31, 2010 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Canon dr 7580 is not scanning multiple pages.
Check if you have selected 'multipage' option. Then you will get only a single file, but with multiple pages.
If your question is that the second or subsequent pages are not pulled in for scanning, then you need to change the rubber rollers.
S. Mohan
Sep 30, 2009 | Canon DR-7580
Duplex Scanning
I havent used WYNN wizard. I use Capture perfect ver 2.0 it is available free of cost. Try with it. If it is okay, then may be some setting is missing. If it remains same, then there be some hardware issue in the scanner.
S. Mohan
Apr 16, 2008 | Canon DR-7580
47 people viewed this question
jasbo
jasbo
