Question about Acer Aspire M3400 PC Desktop
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
Added additional 4 Gb (2x2Gb) Corsair TW3X4G1333C9 Ram. Get Stop errors 0x0000001A and 0x000000DE. Tested in both dual slots 1&2 and 3&4 combination with the original ram. PC has original Kingston DDR 1333 (1x2 Gb) modules. The Ram I am adding is the exact specs as the one in the PC. I have updated the Bios to the newest P01-B4 and set to default with optimal settings. I do not see any option to adjust memory settings in the bios to set it to 1066. I have tested the Corsair ram in windows 7 memory diagnostic and also with Memtest overnight and no ram errors.Crash Dump shows Memory Management and Pool Corruption in File Area errors. When used separately without the Kingston Ram in any of the dual slots the PC runs fine. Please help.
  • 1 more comment
  • Ken L Feb 20, 2012
    Thank you for the response. The specs are almost identical: Kingston ACR256X64D3U1333C9 (9-9-9-25 @667 MHz) Corsair(Dual channel) XMS3 CM3X2G1333C9 (9-9-9-24 @ 666 MHz), both are 1.5V. Which is probably why the PC boots up fine & reports 8Gb Ram (Win7x64). Only after a few applications are loaded it starts to crash with Stop errors. I will check the memorty timimgs. How do I change memort timings? I do not see any option in the bios to do this. Is there a secret setting in the bios to access advanced options? I have updated to latest bios P01-B4. I have tried Ctrl+F1 and other Ctrl & Alt +F key combinations. Could there be any jumper settings on the board? Ram slots on the board are color coded, 2 black & 2 blue for dual channel. I have flipped Corsair in both. The PC is almost 2 years old and has never had any BSOD with the original Kingston Ram. Right now the Corsair is in the blue slots (#3&4) where the original memory was and it is running fine for 4 days.
  • Tony Feb 21, 2012
    what is the make/model # of your motherboard?
  • Tony Feb 21, 2012
    i looked up your computer and unfortunately I am unable to find anything about adjusting the memory timings for this machine. They do have bios updates that you could try and apply and see if it works. Otherwise it is best that you return the ram and purchase an identical ram.
    Master:
  • 451 Answers
Please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Posted on Feb 19, 2012
Testimonial: "Thanks Tony. Appreciate your help. I will get 2 more sticks of identical ram. This is the downside of purchasing pre-configured retail PC's."
  • 3 Answers
Back up system as factory set using recovery console( acer e management) install ram and restore to factory conditions WITH new ram this will auto repair bios to handle ram settings done so on my machine identical to yours my qualifications in computers are adequate enough ( rebuild repair upgrades programming) etc do not try to retime settings allow installation to make changes
Posted on Feb 21, 2012
  • Ken L Feb 22, 2012
    Thank you for the response. I created the recovery DVD's when I first got the computer. I then wiped the partiton including the hidden recovery console and re-installed windows 7. So as per your instructions: I will now need to first back up my current partition with Windows 7 somewhere else. Next install the additional ram and then boot into the recovery DVD and re-install the original partitions with all the software that came with the PC. This would enable the Bios to recognize the Ram correctly? I do not need to run any other Acer utility, correct? Simply restore the PC back to the factory default settings (partitions and O/S) and that should auto reset ram settings in the bios. You say you have done this on the same PC as I have? I will try it this weekend and report back. Cheers.
  • Ken L Feb 25, 2012
    Still unable to add the additional memory. Acer e-revovery management does not start when all 4 slots are used, get error, hardware has changed, and to reinstall windows or contact the manufacturer. Cannot re-install Win7 either, missing boot file error. Once the extra ram is removed able to boot with e-recovery disks or boot into Windows. No Alt+F10 option to start e-recovery after bios post. Can only start it from within Windows and cannot boot into Windows with the extra ram. Reset CMOS, deleted the entire partition, added only 4Gb ( either original or new) & was able to reload O/S from the e-recovery management disks. PC works fine. As soon as I add the additional ram unable to boot into windows or load e-recovery. Cannot even boot with original win7 dvd or Paragon Partition manager. Any other suggestion you can offer? Thanks in advance.
Can you upgrade the processor on a acer m3400
Put a Phenom 1095 6 core in mine and it worked Upgraded the PS just in case. Now seem to have a BIOS problem though probably unrelated. If you google acer m3400 data sheet you can find the specs.
Jul 25, 2012 | Acer Aspire M3400 PC Desktop
I recently added 2 sticks of 1 Gb Ram to my desktop, to now have a total of 4 1 Gb sticks. This newly added memory is PC2 @ 5300Mhz speed. The older 2 sticks of 1 Gb memory are PC 2 @ 6400 speed,...
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
Jul 29, 2011 | ASUS Computers & Internet
I want to upgrade the graphics card on my acer aspire m3400 but can not locate the card on the motherboard
That's because the video is integrated into the motherboard. This PC supports HDMI... what exactly are you trying to 'upgrade'? If the on-board video is not performing as you want, from what you can see here, you may only need to upgrade RAM on your MB:
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM3400/AspireM3400sp2.shtml
#4 at the bottom of the page:
Shared system memory may be allocated to support integrated graphics, depending on system memory size and other factors. Actual system memory available to the operating system will be reduced by the amount of dedicated and shared system memory utilized by the graphics solution and resources required by the operating environment.
Jan 05, 2011 | Acer Aspire M3400 PC Desktop
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hp touchsmart 600 memory upgrade. We have ordered (2) 4 gb memory upgrades for this machine. As far as we can tell the machine only has two slots for memory upgrades and the most recent items sent were (2)...
Maximum RAM supported by this system is 2x4GB PC3-10600 200 pin, DDR3 SO-DIMMs modules.
2x2GB is standard factory RAM. Call back the seller and get a replacement(2x4GB).
Jul 19, 2010 | Computers & Internet
Max supported memory on acer aspire 5672?
This laptop can support up to 4 GB or RAM.
May 08, 2010 | Acer Aspire 5672WLMi Notebook
How do I open case of aspire R1600 to add more memory
YES the Aspire R1600 can be upgraded to 4GB of DDR2 800mhz easily, and I broke no stickers to enter the unit. Here are the websites. with good internal info and photos for R1600. http://tjdmobile.wordpress.com/2009/11/18/acer-r1600-retired-my-appletv-3-0/ http://netbooked.net/netbook-reviews/review/acer-aspire-revo-review/ Solid-PC needs to research more before they answer. "Guru"... hahaha...
Nov 12, 2009 | Office Equipment & Supplies
Trouble after RAM upgrade
sounds more like a compatibility issue with the new ram. Take it or send it back and get a different brand. Or better yet was it running bad to begin with, before them ram upgrade? If so you prolly loaded down with adware and spyware, possibly even a virus. I would suggest doing some good maintenance if thats the case.
May 22, 2009 | Acer Aspire™ T180 PC Desktop
Upgrade for acer aspire 4315
Hi, best and fastest way to increase your laptop speed is upgrading RAM to 4 Gigs, using 2x2Gb RAM modules like this one (UK seller).
Adding a bigger hard drive won't increase laptop speed, but will give you more space to store your files.
Another way to speed up a computer is using CPU overclocking, but this operation, good on old computers, is not worth on a computer with new CPU like yours.
On you tube also some user posted videos on how to upgrade chips on motherboard of old Acer aspire, but I suggest not trying this, as risk to destroy laptop is very high, and it is generally not worth.
Better to stick with traditional upgrades.
Aug 09, 2008 | Computers & Internet
Acer Aspire M3400 PC Desktop Logo
477 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
