Question about Vacuums
Rainbow vacuum just beeps and won't turn on?
Rainbow vacuum making a beeping noise
<p>There is a good change that the controller is bad. Contact us and we can see if it is still under warranty.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Jan 04, 2013 | Rainbow E series Canister Wet/Dry Vacuum
The belt on the power nozzle is so tight that it is not turning and the power nozzle won't turn on when you press the handle
Possible bearing in the motor or brush roll is locked up. Check to see if the light comes on. If it does not, then you have an electrical problem but that is a separate problem from the belt being tight. Let us know if you need service....www.rainvac.com
Nov 25, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum won't turn on
Be sure to that the latches are connected to the water pan. The eSERIES and up will not turn on without the water pan latched. If that is not the issue, please call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 17, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E Series Vacuum won't turn on at all after it just worked fine
Allowing to sit on water pan for only 3 hours is not going to kill your Rainbow by itself. If there is no more information to this issue than what you described, the problem could be the motor is going bad and the thermal cut off is tripped. Possible reason it didn't do it while you were running the unit, is the motor cooling fan kept the temperature inside the motor just below the tripping point and then when you turned the machine off, this allowed the temperature to creep up past the limit and trip the thermal cut off.
RainVac
www.rainvac.com
800-523-0510
Oct 01, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Won't start
Be sure to have it connected to the water pan. The eSERIES and above will not run without the water pan attached. If that is not the issue, give us a call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Jul 30, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum won't power on.
Do you have it on the water pan? All models above the eSERIES will not run without the water pan.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
113 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
