Question about Makita MAC2400 13 Amp 2 1/2 Horsepower 4 Gallon Oiled Twin Hot Dog Compressor
Takes forever to pressure up
I just purchased this compressor and it took about 30 min. to pressure up to 100 lbs.
    New Friend:
Did you install the exhaust manifold that came with the unit?
It was not factory installed on mine when I received it and the set up/break in instructions did not mention it. There is a plastic plug on the side of the head where it is threaded into.
I had the same issue with slow buildup until I realized this needed to be installed - pressures up in no time afterwards.
Posted on Jan 07, 2016
Double check that the drain valve is fully closed on the bottom of the tank. Once it reached 100 PSI, did it stay pressurized or did the pressure drop? Did you run the initial break-in procedure described in the manual? Do you hear any air leaks?
Posted on Oct 29, 2008
Compressor has air coming out the air in take, and has air pressure in the crankcase. When shut off. I shut it off at 150psi.
home compressors should cut out at 100- 110 psi so check / replace the controller
air out of the inlet is air under pressure holding the valves open
pressure in the sump is a blocked breather for the sump possibly from excessive air pressure
remember it is not pressure that drives tools but volume flow so if you have a 10 cubic ft /min compressor but are running a tool that requires 12 cubic ft /min air then 150 psi is not the answer
a bigger capacity compressor is
Nov 06, 2016 | Air Tools & Compressors
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
My Craftsman compressor #919.165310 runs and runs but takes about two hours to get up tp 100 lbs pressure
Hi, my name is John. Welcome to FixYa. Check for air leaks, and clean the filter. Thanks for choosing FixYa....John
Nov 22, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Makita MAC2400 13 Amp 2 1/2 Horsepower 4 Gallon Oiled Twin Hot Dog Compressor Logo
487 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
