Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS will not hold a charge.
The unit was purchased 2007. Do the batteries go bad?
  • achud823
    achud823 Feb 21, 2012
    The GPS is hooked up in the car and my cigar lighter is fine. My car charges only when the car is turned on and running. Do the batteries not charge the GPS when
    the unit is 5yrs old?. Can I get a new battery?
    Top Expert:
  • Magellan Master
  • 44,414 Answers
Well of course batteries go bad
Posted on Mar 06, 2015
  • 373 Answers
SOURCE: International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Posted on Jan 29, 2009
SOURCE: Magellan Maestro 4000 will not hold a charge longer than 30 min
replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Posted on Jun 13, 2009
  • 1111 Answers
SOURCE: My magellan in not holding a charge to well do I
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired, or the part here
Posted on Aug 18, 2009
  • 30 Answers
SOURCE: GPS won't charge
if this is the case take to a repair shop who specialize in gps repair you could try but you would end up making more damage
Posted on Aug 21, 2009
  • 4 Answers
SOURCE: How do I register and charge my Magellan GPS
In order to "register" your Mag_1440 (or any other Magellan), you need to create an account on the Magellan_GPS Web-Site. You will basically supply your name, address, tel_number, e_mail, and the model and serial_number of your GPS... Once you have created your account and registered you GPS, you may be prompted with Links for software and/or map updates... As far as "charging" the 1440/1470, you only need to plug the GPS_Unit into the Car/Auto_Cigarette outlet via the 12v power cord that came supplied in your package... One can also use any standard 120v (AC) to Mini_USB charger (i.e Motorola Razr Cell-Phone AC_Power-Pack) to charge up the GPS unit...Unfortunately, the Computer_USB to Mini_USB cable (in the box) supposedly will NOT power/charge up the GPS... This Mini_USB cable is used to download the latest firmware (v2-20) onto the GPS (approx. 75_MB)... Therefore, before you attempt to download the latest firmware onto the 1440/1445/1470, be sure that it has been sufficiently charged via the Car_Adpater, or an auxilliary AC-Power Adpater... Hope this helps...
Posted on Jan 31, 2010
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Downloaded map update to Magellan 760 - now the unit will not even power on. What can I do? Carolyn
charge it up for a few hours then press and hold the power button till it powers up
Jul 08, 2009 | Magellan Roadmate 760 GPS Receiver
Dec 27, 2008 | Magellan Maestro 4000 Handheld GPS...
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Battery
BertM, I had the same problem and also do not use it frequently enough. The unit finally gave way about 7-8 months. I am hoping that Magellan will honor their warranty and find it's bad battery. I am awaiting an RMA. Visit following site for help:
http://www.magellangps.com/support/askmaggie.asp
Jun 18, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Charge Problem
Hello guitarman249,
It sounds like a bad battery. Theoretically, it could be the charger but if the red light on the charger still comes on when the unit is plugged in then the battery is the more likely culprit. The only way to really know for sure is to try charging the unit with a different cable, such as the USB cord used to connect the GPS to a computer. The GPS should charge when connected to USB. If it doesn't, then it's the battery.
Like most GPS receivers, the battery on this one is not replaceable by the user. If you do determine that the battery is causing the problem you will need to contact Magellan tech support to arrange a battery replacement.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 02, 2008 | Magellan Maestro 4040 GPS Receiver
GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Dec 25, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
272 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
