Question about Nikon Coolpix 4300 Digital Camera
Nikon coolpix 4300 out of memory
My camera says out of memory and I bought a new card. how do I fix it?
  • varao Mar 11, 2009
    same problem, there are no pictures saved and yet it says its out of memory.
  • mfettes May 19, 2009
    nikon coolpix 4300 out of memory with new memory card.
5 Suggested Answers
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
erickg
  • 116 Answers
SOURCE: Nikon coolpix 2100- out of memory- After installing 4gb CF card
format card
Posted on May 24, 2009
  • 20 Answers
SOURCE: Out of memory on Nikon Coolpix L18 camera
There are two ways
1. Upload ALL of your photos to your computer (best if you do this)
2. Buy a new memory card if you don't want to upload the pics to your computer. But keep the memory card safe
Posted on Aug 14, 2009
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Posted on Dec 26, 2009
This card cannot be used Nikon coolpix 4300
Try formatting the CF memory card using the Nikon camera. Go to the Menu to format the CF card.
Apr 15, 2012 | Nikon COOLPIX Cameras
I bought new 4 gb card for my coolpix 4300 and it doesnt work
Remove memory card, go in the menu and check the internal memory is wiped clean, if not! erase all pictures and restart the camera, when that is done the memory card should function once you re-install it.
Mar 17, 2012 | Nikon Coolpix 4300 Digital Camera
I have a 256MB compactflash memory card for the coolpix 4300 that was bought over 7 years ago. I went to Radio Shack and Walmart looking for another. The salesperson told me that the SandDisk 8GB...
According your camera specs listed on dpreview.com:
http://www.dpreview.com/reviews/specs/Nikon/nikon_cp4300.asp
your camera must support the FAT 32 file format in order to use a compact flash card that exceeds 2.2 Gb. I question whether a camera 7 years old supports an 8Mb card, but I haven't found any specific upper limit listed online anywhere.
Oct 22, 2010 | Nikon Coolpix 4300 Digital Camera
I have just inserted a new memory card and it says out of memory
New memory cards must be formatted in the camera first to work properly. Also, you must erase (format) the internal memory.
Jul 14, 2010 | Nikon Coolpix 4300 Digital Camera
Bought new memory card and all it shows is out of memory do not know what to do the book does not explain
Buy a smaller capacity memory card. The camera so far will not support 8GB or 4GB I have gotten to recognise 512MB and am looking to try a 2GB Which I think is the max supported by this model camera
Jun 13, 2010 | Nikon Coolpix 4300 Digital Camera
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
How to use nikon coolpix 4300 for wbcam?
The 4300 cannot be used as a webcam. It only stores images (and videos) to internal memory or a memory card, not stream them live to another device.
Apr 30, 2009 | Nikon Coolpix 4300 Digital Camera
Camera says out of memory after buying new compact flash card 4gb
Go to http://timescience.wordpress.com/2010/08/09/how-to-downsize-a-4gb-compact-flash-card-to-2gb/. That will make the card 2gb and it worked like a charm on my Nikon 4300 coolpix. It will hold 1059 pictures on the fine setting, 2083 on normal, and 4167 on basic. Hopefully this helps, I looked on the computer for hours until I found this.
Dec 20, 2008 | Nikon Coolpix 4300 Digital Camera
Coolpix 4300 needs driver & update for vista
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Apr 20, 2008 | Nikon Coolpix 4300 Digital Camera
Card cannot be used
This means that the card memory can not be read, make sure the contacts are, clean. use pressurized air cans available from most places like, Wal-Mart, Best Buy, Staples, etc.
lightly blow out the memory card and the camera slot, check pin alignment, Format the memory card on your computer first and re-insert in camera. Use another card to see if error continues.
Mar 14, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
193 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
