Question about Kenmore 63672 Convection/Microwave Oven
How do I replace the bulb inside the oven?
I can't find anywhere to replace the bulb inside.
  • 30 Answers
Your 'model number' is incomplete. Find the proper number and go to: http://www3.sears.com/ Enter the model number and you should be able to bring up a parts diagram to show you where the bulb is and which one you need.
Posted on Aug 22, 2006
The bulb lighting the oven no longer works, but we cannot see it anywhere. How can the old bulb be accessed and replaced?
When you remove the outer case, the lamp is situated tucked up behind the door switch mechanism on most microwave ovens and as I have no idea what model yours is, I have to guess.
Hope that helps.
Jan 08, 2011 | Panasonic Microwave Ovens
I am looking for replacement bulb that is found under the microwave 125 volt 25 watt appliance bulb and can't find them anywhere
Most appliance repair workshops will have this type of bulb. Check the base, is it ES, Small ES, Little ES or a manufacturers special.
Contacting the manufacturer will guarantee a spare part.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
HOw do i replace the inside bulb?
Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
Here again my instructions: How do I replace light bulb.
Regards.
Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
INTERNAL LIGHT DOES NOT COME ON WHEN MICROWAVE IS OPENED OR WHEN RUNNING. I AM NOT SURE WHICH REPLACEMENT BULB TO ORDER
the bulb can be taken out from inside the oven just open the boor and look inside for a grill behind this is a light bulb, sorted easy
Oct 20, 2009 | Maytag MMV5207 Microwave Oven
LIGHT INSIDE OF OVEN NEEDS REPLACING --HOW DO I GET TO BULB
normally there is a side door that can be removed to replace the inside light bulb, the microwave bublb is changed from a different location normally on the back.
May 28, 2009 | Microwave Ovens
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replace the bulb in Panasonic microvave Model nn s 768ba
Hi all,
I have just replaced the bulb in my Panasonic NNA873 Dimension 4.
Please be careful,although it was an easy job, there is a capacitor inside which stores heavy loads of power and will release the electricity into you if you touch it!
YOU CANNOT REPLACE THE BULB FROM INSIDE THE MICROWAVE....... DO NOT REMOVE THE CARDBOARD-STYLE COVERING WHICH IS ATTACHED WITH ONE SCREW INSIDE THE MICROWAVE ON THE RIGHT.
To replace bulb will take 5 minutes.
UNPLUG microwave. Remove the outer cover by unscrewing about 6 screws (ordinary phillips) don't lose them into the workings.......
Bulb is located on the right side, nearer to the front. You cannot see the glass of the bulb, only the black plastic end piece, as the bulb sits upside down and vertically. Best if you check out what a T170 looks like on the internet, then you will know what you are looking for. For my Panasonic I needed a T170 (but be careful, they have different ends, some are straight, some right angled - mine was right angled - check before you buy and no, I don't think you can get them from any ordinary supermarket etc!!). Do not touch the bulb when replacing as the oil on your fingers will shorten its life.
Old bulb can be removed by taking out one screw and then pulling off the connectors - there is a little tab to push down to ease them off.
Then simply replace bulb!
When putting cover back on make sure all the tabs on top and sides go inside not outside casing.
Good luck. This is an easy job, just don't poke around anywhere else.
Oct 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE Advantium 120 Convection/Microwave Oven
We can probably give you more specific info if you give us a brand and model number. But here's the generic answer:
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Again, reply back with brand and model and maybe we can get more specific.
We appreciate your thoughtful rating of our answer.
Nov 06, 2007 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
78 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
