Question about Apple Audio Players & Recorders
SPDIF gives invalid on the display what does that mean?
Connected the Optical cablefrommy LG LCD tv to the optical input of the sound bar. No sound and the VERY POOR MANUAL ilive provided tell me the source should be SPDIF and when I select SPDIF I am presented with INVALID. There isn't a thing in the manual about faults. Just another very poor product and manual. I would NOT recommend this or any ilive produce to anyone!
SOURCE: lg tv model rz-42px-11 fault....No picture
Your PCB boards have gone!
Posted on Aug 21, 2008
videotransmi
  • 105 Answers
SOURCE: how do i get the sound from my tv to come throud
Check the users manual for your boombox. Look for information on AUX inputs to the boombox. If there is a way to hook up your tv using AUX inputs it will guide you through the process. For example this boombox by Altec does allow you to hook up AUX equiptment like a tv. CLICK HERE TO SEE IT!
I hope this helps you in yout quest!
Posted on Nov 11, 2009
id1176
  • 17 Answers
SOURCE: iLive boombox is connected to wall plug but doesnot charge iPod
different systems work in werid ways if you cant get it to work by remote make sure its plugged up (right/well) and retry you may have a faulty jack on ipod or the system
Posted on May 13, 2010
SOURCE: I connected optical source toslink to lx700 and have no sound
"programm" button on the front panel for 5 seconds,then choose digital input with left or right arrows button,prees "programm" button again,then change coaxial to optical with volume control on the front panel. then just confirm with "programm" button again and quit the menu.
Posted on Jun 07, 2010
SOURCE: No picture on Memorex MLTD3222 flat panel LCD.
I recently got this tv from somone because of this exact problem. I have found a solution that works for mine. You can check to see if it works for you also. What I did was take of the back cover. 3 screws (1 big one in the center and 2 little ones below it). Next look at the power board. If plugged in and turned on the red light on the power board should be lit up. If so your power board is fine. Next find the component that has 4 switches. I manually turned these on and turned the tv on and it worked! Has been working ever since!
Posted on Jun 27, 2010
LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
Need help connecting to surround sound to a vizio sound bar
hi,
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
ok
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
I have a 50 inch LG plasma tv, not sure of the modal number. But I cannot how to change the output setting to PCM sound that I may use a sound bar connected to the optical port.
The optical output is always on.......you will see that the cable is lit up at the end when you plug it in........you may have to set your sound bar for the optical input though........do you have that manual?
Jun 02, 2010 | LG 50PQ30 50 in. Plasma HDTV
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
107 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
