Question about GE Spacemaker JVM1640SJ Microwave Oven
My ge spacmaker microwave model jvm 1440wh04 shuts down after 3 seconds. the display than lights up with numerous items
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
SOURCE: GE Microwave JVM 1640 BB - Spacemaker
ARE THE LIGHTS WORKING WHEN YOU OPEN THE DOOR?
DO THE CLOCK WORK? IF YES YOU MAY HAVE A BAD
TRANSFORMER,DO THE LIGHTS GO WAY DOWN WHEN YOU
HIT THE START BUTTON? YOU ALSO MAY HAVE A BAD CAP.
(DO NOT FOOL AROUND IN THIS PART OF THE OVEN)!!!!
BECAUSE MOST TRANSFORMERS PUT OUT ABOUT 2200VAC.
YOU CAN AND WILL BE KILLED IF YOU MAKE A MISTAKE HERE. IF YOU NO NOTHING ABOUT HV. STAY AWAY!!!!!!!!!
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Posted on Jan 04, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM 1650 Microwave Night Light does not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
Why does my GE Spacmaker display an error code F4 without turning on microwave whatsoever?
If you wish to get some details microwave repair and Error codes ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Sep 03, 2016 | GE Microwave Ovens
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM 2070 shuts off
My unit does the same thing - it will often simply power down or power down and display garbage on the control panel within a second or two of starting operation.  I have found in my case this seems related to slight obstruction preventing the exhaust hood from pivoting to the open position at the top of the unit.  Mechanical misalignment of the pivoting fan panel seems to cause a motor overdraw, or something similar, which shuts down the unit.  I've found that I can usually slide the pivoting fan panel a mm or so to the right or left, usually right (oddly), and then the panel will swivel unimpeded and the microwave will work.  As my unit has cabinets above it, I believe that over time there has been sufficient physical contact/impact with the pivoting exhaust panel to slightly deform it, affecting its ability to freely rotate down from the vertical.
Sep 24, 2008 | GE JVM2070 Microwave Oven
My ge microwave after running for about 3 to 4 minute it shuts down and will not start up again for 30 minutes model # TH903659B JVM 1650 JVM 1651 what is the problem thanks
If the fan comes on when you put the unit into a cook cycle and all sounds normal otherwise, you most likely have a bad magnetron tube. (Google "GE magnetron failure" and watch how many complaints and articles pop up). The tube overheats and trips the thermal relay causing the unit to shut off until it cools back down and comes on.
Very, very common problem on these models although GE will not admit it.
Jul 11, 2008 | GE Microwave Ovens
GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Aug 04, 2007 | GE JVM1650SH Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
37 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
