Question about Pervasive Software Pervasive PSQL v.10.0 Server - 10 User - PC Volume License for PC
I want pervasive psaql v11 keygen - Pervasive Software Pervasive PSQL v.10.0 Server - 10 User - PC Volume License for PC
Cannot open Peachtree Complete Accounting 2007 as error message states cannot connect to pervasive 9
Apparently your Peachtree system is linked to Pervasive database stuff.
It is possible your system remotely connects to pervasive or you have pervasive software on your machine. It is possible that you subscription to their service ran out OR a change has been made to your Pervasive stuff or computers it operates on that has made it impossible for your Peachtree software to access the databases it is tied into.
If you connect to Pervasive remotely, then check your internet access and subscription status.
Nov 10, 2009 | Computers & Internet
Cannot install in a core 2 quad processor?
Maybe you have AMD and there some problems with the codes and the processor don't understand it.
Jul 11, 2009 | Pervasive Software Pervasive PSQL v.10.0...
User manual FIC V11
There is no FIC V11. There is FIC VC11. Click on the link included;
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=35
Download the user manual.
Luck!
Mike
May 29, 2009 | FIC VC 11 Motherboard
Everytime i try installing sage peachtree on xp sp2 system keeps asking me to update pervasive
You probably have a earlier pervasive version installed or no version. You will get this error when either of those occur. Pervasive workstation is all you need. There should be an option to install it from the peachtree cd. If not open the cd and browse for a pervasive directory and run the setup.
If they didn't include it then you can download it from Pervasive. You should get V10 workgroups install and that error should go away.
Mar 12, 2009 | Sage Peachtree Premium Accounting 2009
Gear
the pleasure of owning a delicate exotica when there are no Guzzi shops within 100 miles your bike can't be moved and your friendly and competent Kawasaki shop is hardly Guzzi knowledgeable (and so am I it seems) ... smile.gif I have broken some transmission bearings and am now confronted (again) with equivalence problems... As you may know the Ghezzi STW is made off parts from V11 and parts from the 1100 Sport. From the picture below would you say it's a 1100 Sport transm' or a V11 trans' ? Yeah, I know, I know, but Bruno Saturno is on holidays and the entire Italian economics is at sleep in august. I have looked here and there are several threads wich mention parts number but as long as I'm not sure which bike donated the parts, I'm stuck smile.gif I have taken a V11 parts list and here's what i need bearing 26 (92 20 80 14 numbers are from a v11 2002 list parts) needle bearing 25 (92 23 40 55) spacer 04 35 51 02 (i actually need to measure it to be sure if it's 0,8, 0,9, 1 or 1,1mm) Are there equivalence between 1100 parts and V11 parts ? (the parts numbers aren't the same on the parts lists). Would you know any parts that would fit from a different origin (SKF ?). Thanx for any help..., well, I just looked in the sport 1100i workshopmanual, there they say replace each 15000km with sporty use or each 20.000 km with normal use. I know they live longer than that. But anyway it is good to take them of each 10.000km, have them in your hand and feel if they move without play. And while you have them there, it's the perfect moment to grease them. And I'm no saint either, I once had one with melted bearing cages. But that was the sort that didn't have grease nipples.,,,
Nov 10, 2008 | 2001 Moto Guzzi V11 Sport Rosso Mandello
V11 neautral light?
which means as soon as the side stand goes down it cuts the engine. Ideas please on what the problem might be and has this happened to anyone else?check the neutral light switch sender on the gearbox,Put a multimeter across it / earth -- should make connection in neutral.,,,
V11 Sport engine rebuilding
My V11 scura also seized but I'm not sure of the cause as I had help stripping the engine I found that I could get a new factory surplus engine for less than the cost of reconditioning the existing engine. Corsa Itialiana had a deal on a new engine It may be worth your while enquiring from them before you get into serious expense.
Nov 10, 2008 | 2000 Moto Guzzi V11 Sport
Pervasive SQL v.8 and 98SE
First I happen to be one of those that like Win98SE (either that or I have too much invested in time - no blue screens for a year) and keep it active on one of my computers....but...if you are using SQL you are getting into at least a middle weight zone....you may have to bite the bullet and go to XP (although NT or 2000 might also be a less expensive solution.) Why? Because if you are building an SQL world you will find other problems downstream where "tried and trusty" is going to cause you more time (and I mean a bunch) in solving problems than it's worth. Since I don't know what the "crap" says in the box I can't respond with more than this but I doubt there is a patch from Microsoft for this....Pervasive on the other hand should be able to give you some thoughts. Good luck.
Jan 21, 2008 | Pervasive Software Pervasive.SQL 8...
Pervasive Software Pervasive PSQL v.10.0 Server - 10 User - PC Volume License for PC  Logo
678 people viewed this question
Top Pervasive Software Computers & Internet Experts
David Payne
David Payne
Are you a Pervasive Software Computer and Internet Expert? Answer questions, earn points and help others
