Question about Lexmark X3480 All-In-One Printer
Unable to find cover switch
Please help me to find the cover switch
Naz
I assume you have the 'Cover Open' problem. I have just had the same problem.
You have to remove the top cover, then remove the scanner - but take care not to damage the ribbon and power cables. The cover switch is in a hole an inch or so to the right and up from the centered cartridge. It is a micro switch operated by a white bit of plastic. The chances are this has become detached and needs to be located from the bowels of the printer. It can be snapped back into place or the mocr switch taped closed.
To take of the scanner you have to squeeze or twist out the pegs on the support arm, then open the hinges to release the scanner. HOWEVER before releasing unplug the ribbon and power cables !!
Good luck
Posted on Oct 31, 2008
Over head mic came out of slot
Hello, Naz.
The same thing happened to mime.
There is a plastic notch that prevents the metal arc piece (which slides into the plastic housing to adjust the length of the head rest end) that probably broke.
What I did to fix mine is to get a little zip tight used to wrap cables together and used it near the end of the plastic housing to hold the metal piece. You should tie is as hard as you can (BUT WITH THE META PLACED INSERTED - other wise you can break the plastic housing), and cut the strip with a scissor or cutter plier. In fact, in mine, I can even slide and adjust the metal band as I wish and resume normal operation of the headset without any problems.
I hope it will help your.
RC
Sep 06, 2014 | Naztech Noisehush N700m Over-the-Head...
I am unable to print documents from computer. I
There is a switch on the right and the cover press it when it closes.Put a small paper to help the cover small plastic stick on the right to keep the switch pressed. Then you will print normally
Oct 26, 2009 | HP PhotoSmart 7960 InkJet Printer
I m unable to switch on my sigma fxd t99i pls help me
Dear Sir
I have A China Mobile (NXD e600)
...High Speed Sim selected, It appears SwithOff after 3 seconds and unable to switch on. Please help me.
Srinivas Sigireddy
Kakinada
srinu.sigireddy@gmail.com
Apr 10, 2009 | Handmark Software MobileLists (950142) for...
Crown amp xs900 will not reset
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
Features
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
Inputs
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
Output
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Dec 31, 2008 | Crown XS900 2-Channel Amplifier
Unable to print and copy
pls check the trigger switch of the back cover
Oct 16, 2008 | Brother MFC-7420 Printer
Printhead cleaning
Hi, in desktop right side down you can see the printer icon click right select head cleaning.
Mar 01, 2008 | Office Equipment & Supplies
Unable to shut door on battery and memory card cover
some memmery cards have to click in. press in click, press in click out. or memmory card needs to be turned around.
Feb 01, 2008 | Olympus Stylus 790SW Digital Camera
Games and applications "operation failed"
if you have manufacturers gaurantee take it back to the store of purchase may well be a virus or corrupt file on memory card try reformat memory card.
Naz.kklso
Dec 31, 2007 | Sony Ericsson W850i Cellular Phone
Cover change for nokia 7373
Download the Serice manual, google it.
Dec 17, 2007 | Nokia 7373 Cellular Phone
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
Lexmark X3480 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
