Question about Intel Computers & Internet
I got a pc and put a password as the admin so my kidz wudant download anthing without me knowing.the problem started when after using the pc for a litl the software proved to be not genuine.so I thot id get new software for it,but now I have forgoten the admin password.so im finding it imposible to upgrade the pc.any ideas?
SOURCE: Admin password
login root
password pass
hf
Posted on Oct 15, 2008
Geekman
  • 32281 Answers
SOURCE: need to reset or erase admin password
There are Linux password removal programs on the Internet. It is designed to remove passwords on NT, Win 2K and XP.
You copy the program to a CD and boot up from this CD. It allows you to reset or remove the users and administrator passwords.
Google search for these programs "password recover" There is another solution. You can reinstall windows and this will give you a clean computer and possibly better performance without the accumulated junk/rubbish. Don't forget to get/download all the device drivers (eg. video, audio, modem,NIC etc.) before you start.
Posted on Jan 11, 2009
botaksetan
  • 80 Answers
SOURCE: can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
comssg
  • 5 Answers
SOURCE: my son lost the installation disc is there a way we install without buying a new camera?
Driver Website http://www.sakar.com/productdetail.aspx?id=218&return=y&txt=web+cam&page=7
Posted on Jun 06, 2009
SOURCE: how can I find the admin password on my mac
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
Posted on Feb 10, 2010
For got admin password
If i forgot Admin password, what should i do?
Step1: Download Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to reset forgotten admin password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Jul 11, 2012 | HP Computers & Internet
ZT Computer
If you lose windows Vista password, then you need to reinstall Vista. Use your recovery disks.
Apr 21, 2008 | ZT Group CISNET A7050 PC Desktop
Bought used laptop and do not have administrator password
You can reset laptop password with Smartkey Windows Password Recovery, just do as the following steps,
Step1: Download Smartkey Windows Password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step5: Start to reset laptop admin password with the burned disk.
Jun 04, 2012 | Toshiba Satellite A15-S129 Notebook
Need to reset or erase admin password
Jan 10, 2009 | Panasonic Toughbook CF-51 Notebook
I have an acer Aspire 3690 laptop and I put a password on my admin user name and now can not remember that password is there anyways without having to reload everything on here that i can find my password?
do any of the regular accounts have admin rights? if so you should be able to go to --
Start -> Control Panel -> User Accounts and change account info from there
let me know :)
Dec 25, 2008 | Acer Aspire 3690-2196 Notebook
Admin password!!??
Emergency Boot CD is a download you can find many places. Burn to CD and then boot off of CD, it has an option to change user passwords, including Administrator.
Here is a link to download
http://www.brothersoft.com/emergency-boot-cd-62611.html
It is FREEWARE meaning you can use all you want and never have to pay.
I actually used the Admin reset functionality. I fix computers for my church, and whoever used the computer last put a admin password on it and then left the church. I was able to reset and get back to a working computer without any problems. Works great.
Dec 14, 2008 | E-Machines C3060 PC Desktop
Forgot admin password to my system.
Dec 13, 2008 | Microsoft Windows XP Professional With...
Windows vista admin password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jan 25, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
