Question about KitchenAid Architect II KEMS378SSS Stainless Steel Electric Double Oven
My microwave doesn't stop
  • Alexandre Hart Feb 19, 2012
    that combo unit is new from 4 month, there technician came 3 time,couldn't fix it, so they send me another one,,and still doesn't stop at the end of its cooking time...when it gets a 0:00,it beeps as normal 3 times but doesn't stop, NO heat BUT the fan,the light and the turn table stays on
3 Suggested Answers
aroracaty2
  • 503 Answers
SOURCE: My kitchenaid 30" built in
what you need to do to fix up oven back again
is that you will have to locate the element of your oven it has develop a lick-age from it some air get escape from it and
the element is the heat provider for your oven that allow it to carry out it function has an oven it is always in silver colour and it is connected to the maize (the wire or the hose from the gas ) which supply power to it
unscrew the oven from the back and trace the wire or the hose that connect to the element
please do this with care to avoided more damage on it
OR
You have one or two possibilities here, one is your control board is going out. The second and most likely problem which is usually associated with this error is that the Latch to the door, or switch is failing causing this message to appear. You need to replace the latch to fix the problem. A new latch can be bought from the place you bought the oven or from RepairClinic.com
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 29, 2010
heatman101
  • 43501 Answers
SOURCE: microwave has power...light lights and turn table
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 19, 2010
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 05, 2011 | Ovens
Unit stopped working. no microwave or turn table movement, but timer counts down. Any thoughts?
Basic
heatman101
Dec 23, 2010 | Frigidaire Ovens
Oven problem
Hello,F1 means the circuit board is defective and you need to replace the control board.
Thanks
May 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
KitchenAid Architect II KEMS378SSS Stainless Steel Electric Double Oven Logo
94 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
