Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
I need to change the freezer seal on my refrigerator. But they did not send me any directions on how to do it.
I need to know how to change the seal on my refrigerator freezer and do not know how to do it. I need directions.
    Novelist:
  • 124 Answers
Most of these have a hardened plastic female channel thats tough to see . it is a part of the door and consealed under the old gasket. it has a hollow groove . usually the new gasket has a flat side with a dart or double dart piece sticking out . this dart or arrow side runs the entire side of the gasket and smushes into the door groove channel.. usually you start on a corner firmly pulling out the old dart and gasket from the channel groove. clean the old channel with mild detergent and a little brush. wipe down. lightly oil door groove channel with a little veg oil on a rag and get ready to mash the new dart onto the channel all the way around. it takes great finger strength and mashing one thumb on top of the other to get enough pressure but it can be easy on some. good luck .be sure to clean door sill mating surface and wipe with oily Veg oil rag so new gasket stays clean and doesnt stick. it may take a few days to break in and level out. be sure your snug all around when done. lay out new gasket nice and flat in warm room before you start.
Posted on Oct 26, 2008
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
Sides and top hot to the touch
dear sir/madam'
i think its low gas problem so kindly contect to your sevice technician for refill refrigerent gas and also change freezer,s door seal ,
thank you
hope answer the question
please vote!
Jul 30, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
The freezer is not cooling
If you are getting some cooling the 2 most common suspects are the door and refrigerant leak.
Check to make sure the door/lid is closing all the way and the seal is good. You can put a piece of paper or dollar bill between the seal and cabinet there should be some resistance to pulling the paper out all around the seal.
If the door is not the issue and this is not a frost free unit ( I would need the complete model number from the product to be sure) then the next most likely culprit is that the refrigerant has leaked from the system or the compressor has become inefficient and can no longer circulate the refrigerant. A new compressor replacement would run around $400.00
Apr 26, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Woods freezer has thawed twice in the last year.
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. this will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
Concerning the defrost switch:
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced.
Dec 24, 2009 | Woods Freezers
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
No longer freezes
The evaporator fan in the back of the freezer blows over the cooling coils. Those coils are typically hidden from view behind a panel.
The problem you describe would lead me to suspect that the coils are iced over. That is why there is some cold, but not enough. The fan is blowing over a block of ice. An overfilled freezer is another possibility.
Iced over coils may be the result of a malfunctioning defrost system, a plugged drain tube, a poor seal on the door seals to the cabinet resulting in a lot of moist air entering the freezer (or fridge) or the refrigerant level is under pressure (needs more refrigerant added).
Most refrigerators never need refrigerant added, but after 25 years, it could be that yours does. However, it can only be done by a pro, and it probably isn't worth investing that kind of money in such an old fridge.
I recommend you start by unplugging the fridge and inspecting the coils inside the freezer. If they aren't iced over, then the door seals may be still be the problem by letting in warm air.
Jan 19, 2009 | Avanti Freezer CF62
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
293 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
