Question about Video Cameras
Low battery do not have manual don't know how to charge battery
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Video Cameras Master
  • 102,366 Answers
You may download the 410 manual here.
Posted on Feb 19, 2012
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
My phone keeps saying "use
the LG chocolate is bad and knowen by battery problem and low capacity,, with your problem you must get new battery with best quality but I recommand you to change your mobile when you go back from Puerto Rico and have a good vacation.. ;)
Jul 20, 2011 | LG CHOCOLATE VX8500 Cellular Phone
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
Hello. I do not use my rx330 frecuently,to keep my battery charged may l use a battery maintainer conected directly to the battery car or l have to keep conected to the battery without the car. How can l...
if your battery maintainer(charger)has the capability to charge from a higher charge to lower charge as the battery gets charged up and shut off when proper voltage is attained then you can leave the battery in the car as every time you disconnect it you have to reset everything in the car.some now can detect when to turn off and turn on as the car sits and voltage drops to low.don`t know which ones do and don`t someone may be able to answer that if they know about them.
Jun 13, 2011 | 2004 Lexus RX 330
I dnt hve my owners manual and I need to know wht fuse and relay is connected to my compressor. Please help. 2007 sebring
i assume you are refering to you a/c compressor .----- the fuse covers under the hood & on driver's side dash should have a listing on the back side , if you don't have the covers try checking for a repair manual at your library . these fuse & relays don't normaly go bad unless the compressor is bad or a short in wires . if you a/c does't work at all it's probaly low on freon charge, there is cut-off swithes built in to the system so the compressor does't run with out lubercation that is carryed by the freon.
Jun 05, 2011 | Air Tools & Compressors
I have a1999 Honda VFR800FI motorcycle. If I fully charge the battery, I seem to be able to ride for about 1 hour or so. Could my generator be bad or something much worse? I'm only getting 12v to the...
G'day,
You say you are only getting 12v to the battery(& I presume you tested this with the engine running) then that is too low.
It needs to charge from about 13.5 to 14.2volts(DC).
Common causes of a low charge rate are,
Faulty voltage regulator.
Faulty alternator(stator usually).
You need to have these items tested to dertermine which is at fault.
Unless your experienced, faultfinding charging systems can be tricky & you need a couple of special tools too do it efficiently.
If your up for it- & have a multi meter,
You can start by disconnecting the wiring at the regulator.
Using the meter set to resistance-ohms times 1- check between the three yellow wires-yellow to one yellow then the other-see you get same readings & should be quite low(just a couple or few ohms)
Now set your resistance scale to max.
Probe between each yellow wire & earth.(don't let your fingers touch the probes-it will give a false reading)
There should be NO CONUNUITY- Any reading between the stator yellow wires & earth means a faulty stator.
As for the regulator- there all different so manufacturers specs are usuall needed.- as are test procedures.
Hope this has helped some what
regards Andrew Porrelli
May 12, 2011 | 1999 Honda VFR 800
1982 Yamaha XJ 550, the battery will not take a charge. New battery, checked all connections, ran all the tests (stator, brushes, and alternator). Replaced the voltage regulator/recifier. Not sure what is...
It is corrected properly, right? + to the wiring harness and - to ground ... right? Are you certain about the rectifier? Is the battery charged at this time?
You know a alternator cannot make power unless you first put power into it ... right? Alternators (unlike most generators) are not self exciting. If your battery is weak or "dead", the alternator cannot make electricity to charge the battery. I don't know what the rating of your alternator is. Your battery should be fully charged before you do any more tests. If you have a 1 amp charger, allow at least 10 hours for a full charge. Don't cook your battery with a big, powerful, fast charging automotive battery charger.
Good luck with your repair ... I hope you find this response helpful.
Thanks for your question @ FixYa.com
May 02, 2011 | Yamaha XJ 650 Motorcycles
MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Oct 02, 2009 | Electronics - Others
Video Cameras Logo
21 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
