Question about Dell Inspiron M5030 PC Notebook
Why won't my laptop start up?
When I turn the power on it beeps 4 times, pauses, beeps 4 more times, and just continues while never starting up.
  • Anonymous Mar 30, 2014
    Replaced a battery tonight-- when turning on the laptop continually beeps three times-- screen is completely black
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
According to the manual a series of 4 beeps indicates a "RAM read/write error". Do you know how many sticks of memory you have in your laptop?
Posted on Feb 19, 2012
2 Suggested Answers
  • 69 Answers
SOURCE: 4 beeps
try to replace ram memory basicaly that`s the problem if u have 2 dimm`s try starting it up with one if it does the same try the other one and if is the same try to change the socket of the ram
Posted on Mar 13, 2010
T6520 emachine won't turn on, lights and fan work. Beep code
Hi, you are having a problem with your add on cards, try to pull out everything that you have add on to you PC, then try to put 1 by 1 and try to turn on. If it beep once its OK, but if it's continue then the add on cards are the defective.
Oct 08, 2012 | E-Machines eMachines Desktop PC
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
My Dell Inspiron 530 won't start. 4 Beeps, Soild blue light.
According to Dell this is a RAM issue. You can find a list of diagnostic Beep Codes here. Also be sure to inspect the capacitors on your motherboard. If you notice any of them leaking or blown then that is your problem.
If you have extra RAM lying around then swap it into your PC and see if you're having the same problem. If not, pull out any unnecessary RAM just to test it. There are four RAM slots on this PC and you should be able to use any one of them. If your PC turns on then you can isolate which chip is giving you problems. Keep in mind RAM is ideally installed in matched pairs.
If you only have one RAM chip in your computer then I'm afraid you will either have to buy another one or borrow one from a friend to test. Shouldn't be too expensive anyway.
Jul 24, 2012 | Dell Inspiron 530 Desktop Computer
Won't start...3 short beeps, pause and continuous repeat
This is a hardware warning, Usually memory modules the way to test that is take one of them out at a time if the beeping stops that is the one that is bad you can do this for all of your hardware parts inside. even DVD or CD burners just remove the power from each one of the hardware suspects. Upon doing this you will find the part that has malfunctioned you will need to replace it. John
Apr 09, 2012 | Computers & Internet
My Dell Dimension 5150 won't turn on. it makes a long beep, pause, and 3 long beeps, then pause, then 2 long beeps. what's wrong with it?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Feb 29, 2012 | Dell Computers & Internet
Power on just get continious two second beeps
sounds like not enough power. have another look at the board, the 4 pin connector should be near the I/O shield near the top of the board, just above or beside the CPU. sometimes it is on the edge of the motherboard (so the plug pins are parallel with the board surface)
Feb 17, 2012 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Fujitsu Siemens E620 - i915G does not start. Earlier it made continuous restart cycles. After cleaning a lot of dust from inside of the case it does not start any more. Gives different beep-codes. a - 4...
Remove power cable.
Remove the RAM(s) and clean the RAM slots.
Remove VGA card and clean the AGP slot.
If there is dust on RAM(s) or VGA, gently and slowly wipe with a clean cloth.
Re-insert RAM(s) and VGA.
Reconnect power and start the computer.
Let us know the result.
I must congratulate you on cleaning the machine yourself. Some Fujitsu Siemens machines are so difficult to take apart for cleaning.
Sep 10, 2011 | Computers & Internet
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Dell Inspiron M5030 PC Notebook Logo
612 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
