Question about Whirlpool Washing Machines
Whirlpool washer basket loose
Washer basket sitting low and seems loose. laundry off balance
  • Andrew Alexzulian Feb 18, 2012
    the drive shaft may be worn out or the bearings. if its a cabrio the drive shaft will rust away. what make ,what model .
  • jemsw
    jemsw Feb 18, 2012
    Whirlpool Ultimate Care, Two Speed Automatic Washer Model # LSN1000JQ0
dauphine
  • 207 Answers
SOURCE: maytag washer goes off balance
Several shock absorbers are used to internally balance the basket. Most likely they need to be replaced. It is a typical malfunction. Not expensive and can be done quickly by experienced DIY guy.
Posted on Apr 16, 2008
codfish124
  • 36 Answers
SOURCE: gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Posted on Dec 20, 2008
  • 718 Answers
SOURCE: Need to disassemble Whirlpool Ultimate Care II washer
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
Click on the model that matches your machine.
The new window will give an assembly diagram of your machine. Clink on the diagrams on the left-hand side for different assemblies.
Posted on Apr 11, 2009
  • 901 Answers
SOURCE: the basket inside the washers seems loose
Ball bearing housing got damaged or the drum shaft that holds ball bearing center race is worn!
Posted on Apr 06, 2010
Testimonial: "That helps, is there a manual out there? Thanks,"
SOURCE: I have the whirlpool LTE5243DQ6 model stack 24in
One of the three suspension legs supporting the washer drum has broken. This model is prone to this. I had mine serviced before the warranty expired and the service guy showed me how to do it. Much the same as replacing a worn shock on a car, the front panel of the washer is held in place by two hex screws that can be accessed by 'popping' the top panel of the washer unit. Once the screws are removed, you can then access the whole unit by disconnecting the wiring loom and the internal water hoses. Sometimes if the suspension leg isn't broken, you can screw it in place and secure it with a screw. This is what the service guy did, but it came loose in a few months. There is a new kit that replaces the old suspension legs but I haven't ordered it so I can't comment.
Posted on Jun 08, 2010
When it goes into the spin cycle, the inside "basket" seems off kilter and wobbles noisily
This may be due to an unbalanced wash load. When you load your washer, try to distribute your laundry evenly in the basket. Try to balance heavy stuff opposite each other.
Hope this helps.
Mar 05, 2015 | Washing Machines
Wirlpool wtw4800xq washer frequent out of balance
Check the spring rods on each corner make sure not broken or came off pull basket make sure nothing in between silly question is it level also check the balance ring to make sure it is not loose
Feb 17, 2015 | Whirlpool WTW4800XQ Top Load Washer...
The wash basket is off and there are pieces of melted plastic in my clothes.
Check whirlpool website for recall. Check fan belt for wear. check basket housing holder for loose screws or bolts. Check to see if you purchased an extended warranty. last check to see if store you purchased from will help with repair cost if you did not get extended warranty.
Nov 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Balance, washer shakes and walks across floor
Have you checked to make sure the supports are OK? Is your washer making loud noises during spinning? If so, the basket drive may be broke.
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After using my Whirlpool Cabio Top Load Washing Machine to do a load of laundry, I can still hear water sitting inside.....What can I do?
There water in the balance ring at top of basket/that has to be in it...Can you see water at bottom of basket?
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a kenmore stackable washerand dryer that is less than a year old... the problem is that my basket in the washer sits crooked like there is a spring or something off... so now i have to wash minimal...
Yes if its less than a year old call for service it will not cost anything. there are supports under the tub that support the outer tub and basket that have come loose
Oct 05, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Gasket came loose and rapped around laundry-tub seems loose
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Basket out of balance
YES !! also could be a loose or broken screw that holds the inner basket , hope it helps AJ
May 21, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool washer LSQ9659pw4, very excessive vibration and walking
hello im proably the only one that will jump on this how old is this unit
Mar 29, 2008 | Washing Machines
Washing Machines Logo
239 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
