Question about Denon DN-961FA CD Player
Error #'s on screen 37-67 at boot up
I have three units in for repair, two have 37-67 displayed when powered up, the other has 46-78. None of the units will go past this "locked up" to perform any functions or to repond to any commands.First unit I had put in an optical assembly, no difference, swapped front control face panel, no differnce, then swapped the servo pcb. The condition follows the servo pcb. The service manual doesn't cover this area at all. So I tried the microprocessor reset procedure from a DN 995R (broadcast mini disc)that is to press the "select knob" and "stdyby/cue". this did make the screen go blank while holding them in but it comes back to displaying same #'s and unit is non reset and still non-responsive.Any help is greatly appreciatted
Of course now that I need it again, I can't find the "3-Button" reset...
Posted on Nov 25, 2008
Ok, I had this issue forever and had a pile of machines that I was going to use just for part. partstore doesn't have this piece. no place has that servo unit.
Until I found it on a german site.
my german was terrible, but the CPU needs to be reset. I fixed 8 broken CD players with this same exact issue.
I'm looking for the manual online to tell you... but I can't find it.
Posted on Apr 11, 2008
  • revaaron Apr 11, 2008
    ps: the # on the screen references the chip on the servo board.
  • revaaron Nov 25, 2008
    of course I can't find the "3-button" reset info anywhere online now.
    arg!
Yes , I finally replaced the servo pcb #GU2515. I googled that part # it it came up under www.partstore.com they got one to me in about two weeks. $206 plus shipping. It cured all three machines, got them off the bench and back to the customer. Good luck
Posted on May 08, 2007
I have a unit with the same problem, did you ever get anywhere with this fault ?? Regards, Stuart
Posted on May 04, 2007
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
Computer will not boot up, only goes to the windows error recovery page, options to start repair or windows normally, none work it goes back to the same page...
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Jan 07, 2011 | Acer Aspire One PC Notebook
My hp g61 will only display a blank/black screen with the cursor after it has finish booting
That cursor is the way in which the BIOS of the laptop is telling you that Windows is completely corrupted and unbootable. You will need to reinstall it so use the recovery cd that came with the laptop.
Dec 28, 2010 | HP G60-120US Laptop
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Screen Shut off
Hello
If your Notebook is not powering on then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If your Notebook is powering on and you are unable to use any feature. Then I recommend you to repair Operating System of your Notebook. This will not delete any data . It just repairs the operating system files.
Here are the steps to perform Operating System Repair.
1. Ensure that the CD-ROM is connected to the Notebook.
2. Turn on the Notebook.
3. Immediately insert the Operating System CD into the CD drive.
4. Press and hold the Power button for 5 seconds to turn off the Notebook.
5. Press the Power button again to start the Notebook.
6. Press any key to boot from the CD, when prompted. The Welcome to Setup blue screen is displayed with three options.
NOTE: Please donot select "R" option directly from the three options displayed.
7. Press <ENTER> to continue. A Licensing Agreement screen is displayed.
8. Press <F8> to accept the Agreement and continue. Another blue screen Setup window is displayed.
9. Press "R" to repair the selected Windows installation.
The repair process may take several minutes to complete. Your Notebook will restart into Windows after the process is complete.
I hope this will work.
Thanks
Aug 24, 2008 | HP Pavilion ze2000 Notebook
Denon DN-961FA CD Player Logo
218 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
