Question about Samsung SyncMaster 216BW Monitor
All buttons are not working
Any buttons i push, the monitor dont react. But if i unplug and then replug it, it react for 2 sec and after this nothing.
  • Eaglephil999 Oct 26, 2008
    sorry for the details, it's my monitor's buttons that doesn't work. It look like a lock mode but there's no lock message.
    Problem Solver:
  • 7 Answers
Are these buttons on your monitor? or Keyboard?
if they are buttons on your monitor you may have installed a graphic or colour balancing piece of software (maybe associated with an update to GFX card software) This would explain the reason they work so briefly, as this is the time in which the process that is causing your trouble, starts up.
Press Alt+CTRL + Delete to access the Task Manager in windows... go to the Process' panel, then take a good look thru to check if there are any graphic management software tools in startup.
try stopping some (this cannot do harm as all will reset on next re-boot) and seee if this helps.
Of course this possible solution check is only for monitor related issues.... if it's keyboard, then it's a totally different issue... Although still likely to be recent software installation related.
Could also try typing msconfig in the 'run' box to get access to a selective startup which will let you narrrow down the new and possible baddies - however i should warn that you Can Do more trouble with MsConfig that you aimed for if you are a novice user.
give more detail and i will attempt to help you further.
good luck
Posted on Oct 26, 2008
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My remotes will not activate the opener from anywhere but inside the garage. Worked fine the first month then stopped
2 possible solutions; #1) unplug the motor for 3 mins then replug (resets memory) #2) on back of motor is a "learn button" - press learn button for 3 sec, then press your remotes for 3 sec.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Monitor power button just flashes blue then yellow , does not work on other computer or other cable. Though it has to be solid yellow, It flashes even with no video cable. Thanks in advance for any...
If you have the power button "on" on the monitor and you unplug the vga cable from your monitor you should get a messege about the cable being unplugged. Sometime the inverter in the monitor can go out and you will be left with a very dim screen or no image at all. You can call up a local computer store and see if they can test the monitor for you. Taking the monitor into a repair shop will more then likely cost you more then a new monitor. I would check to see if the monitor is still under warranty or simply just replace it.
Best of luck..
Nov 18, 2010 | Hannstar I-Inc TW-191D Monitor
I recently placed my computer into storage. When I took it out and set it up, the CPU seemed to be running but there was nothing on the monitor and the keyboard didn't seem to be functioning. The mouse...
unplug the power cable of the CPU
press the power button for about 5-10 secs
open the tower and reseat the memory
theres 2 white clips on each side press down the white clips until the memory pop out
check the memory if theres any dust and put it back the way it was before
push the memory back in with a small force until the 2 white clips snap in
hope this help
Sep 07, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
My monitor wont switch on staright away just makes a popping noise then turns off
try this: unplug monitor and detach it from the PC . Then push in the monitor ON button and hold it for at least 60 seconds. Replug it and it likely/may work --you are basically resetting it.
Mar 21, 2010 | E-Machines eMachines Monitor E15T4
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
LG 1710 monitor has stopped displaying. On/off button just flashes green but no picture appears. Was working fine, no config changes made.
try unplug it from the outlet. wait 10 sec and replug it in.
the video driver might be corrupted.
go to lg wen site and download the lastest video driver software.
Oct 12, 2008 | Computers & Internet
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Aug 05, 2008 | LG Computers & Internet
Samsung SyncMaster 216BW Monitor Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
