Question about Intel Computers & Internet
Im using intel fw82801eb desktop from month im facing a boot from cd rom problem . when im trying to boot from cdrom with bootable windows xp windows 7 he skip the cdrom n go to other boot option . what can i do plz help me my email address is humayon143@msn.com regardz, sam
  • humayon143 Feb 19, 2012
    i have checked n change the option many time . when im tryin to boot from usb cdrom i got same problem
    New Friend:
  • 84 Answers
HI
PLZ CHECK YOU BOOT MENU UNDER BIOS
AND SET THE CDROM THE FIRST IN THE MENU
Posted on Feb 18, 2012
  • cbtmaya
    cbtmaya Feb 19, 2012
    HI
    ARE YOU SURE THAT YOUR CHANGE ARE SAVED AFTER QUIT THE BIOS WINDOW
    PLZ CHECK THAT
I have a mercury board kob p4266ndfsmx, with intel processor and 1 gb ram, dvd writer is working fine, problem is im not able to boot from cd rom even if i choose cdrom as 1st boot device, i have check...
sometime there are an option in the BIOS setting to boot directly on HDD when there are a OS installed try to invert primary and secondary controller (invert HDD and CD-ROM wire on the motherboard)
Nov 29, 2012 | Mercury P4VM800M7 Motherboard
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
Corrupt missing C:\windows\system32\config\system no original windows xp oem disk cannot use recovery console cannot get to a c:/ prompt no floppies have cd rom bios does not support usb boot possiblity...
Your master boot record of the hard disk is damaged. I suppose you have access to CDROM through bios. But it is not clear from your question. Set CDROM as first boot device. Get a bootable CD & make sure that it contains fdisk utility. Boot from it & you will get a:\ prompt. at a:\prompt type fdisk/mbr & press enter. Your master boot record of hard disk will replace. Now you will be able to go to c:\ prompt. Use your your xp cd to recover your windows.
-sonsunny
Jul 14, 2011 | Dell Dimension 8250 PC Desktop
System can't bootup any cd or dvd
Do you have a Win98 install CD? If yes, you should be able to tell it to boot with CD-ROM support.....then use xp disk to load or install your OS.......I'm doing that right now on a different system. It will format your drive first....which takes a looooooooooooong time, however, it is worth it.
Sep 27, 2009 | Intel Motherboard
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
Xp not installing
first configure your hard drive in the bios set your harddrive as primary drive then configure the booting setup you must boot first the CD ROM drvsave setting and exit. Then if you have a bootable disc installer for XP any OS insert in in the CD ROM drve. wait for a while then follow the instruction that goes out in the desktop.
Jan 08, 2009 | Microsoft Windows XP Home Edition
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Cd rom
It depends on the symptoms. Insert a cd in the drive and check what exactly happens when you go to My Computer and double-click the drive letter for the cdrom?
What error do you get?
Oct 03, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
