Question about Ricoh Aficio 2018D All-In-One Laser Printer
When i print use counter meter i see good result, but i print used scanner i see have a black line...
    New Friend:
  • 84 Answers
HI
CLEAN YOUR VITRE SCANNER
Posted on Feb 18, 2012
How do i know how many copies have been printed on a ricoh FW870? i want to sell it and give the mileage?
it have a electronic and mechanical meter. on this type of printers the mileage is not in print but in meters, so the electronic one you can check by pressing on the upper left keyboard the key on which writes "123" and then look up for counter. you can even print the counter. also this machine have and a mechanical counter. as you see the machine from the front, somewhere in the middle of the machine. where you replace the toner. or if you have not ever replaced the toner is in the same level where is the manual feed table. you will see in this line of the machine, on the right and left side have a grey press buttons. you need to press them up and the machine will open in the middle. so when you will open the machine you need to pull up the upper part. so on the right bottom part you will see the mechanical counter.both counters are expressed into metters.
Sep 20, 2016 | Ricoh FW870 Black and White Copier
How do i find the w&b numbers to input for my monthly meter reading?
User tools button then counter then select print counter that will give black and white total count use that number
May 31, 2014 | Ricoh Aficio MP-201 Copier w/ Duplex...
2 lines print on the page.. one on the left edge and that other is about inch and quarter in from the 1st one...
Is this just for copying? Or do you have the machine connected to your PC as a printer? If it is just copying then try making a copy from the glass. If the lines go away then this means you need to clean the strip glass which is located just to the left of the large main glass. If the glass copy still has lines then print out the meter count sheet by pressing user tools/counter then at the lower right corner of the screen press "print counter list" then press the print key. If lines on this sheet are still present then you likely have wear lines or grooves in the surface of the drum and may need the PCU/Drum Unit replaced or rebuilt.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Check the meter on a Ricoh MPC5000
On an MP C5000, press the User Tools button on the operation panel, then on the touch screen press Counter.
You'll see the various totals for copying and printing, and it will be broken up for color and black & white. If you want to print out a sheet with all of the meters on it, just press Print Counter and then hit the green Start button.
Jul 06, 2010 | Ricoh Aficio AP3200 Laser Printer
Aficio MP1600 - Black Lines are appearing on all copies. One line appears on the ADF copy but muliple lines if using the scanner. I have tried to clean with a damp cloth everything possible, no good..What...
Try to print from the machine, such as function list or counter list. If no lines, then confirm the ADF scanning mirror dirty. If got lines, the probably came from fuser unit or drum unit.
Jan 20, 2010 | Office Equipment & Supplies
Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Line across the page
  1. Make a copy by using the platen mode and ADF.
  2. Send a print from your PC or print out the Counter list from User tools/counter button.
  3. Try printing one colour at a time - Black, Cyan, Yellow or Magenta.
If when printing, there is no line across the pages, so you need to clean the optics mirrors and exposure glass.
If the line appears in both 1 and 2 mentioned above, you have the fuser roller or drum damaged.
If the line appears in all colour prints, check the fuser or transfer belt.
If it happens only with one particular colour, check that drum unit.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSc328 Copier
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
The printer cannot print and show "L" in the number display.
Is the copier just stirring and making a noise? If so it is tring to add toner, but it can not find any.. The meter count or yield of a toner cartridge is rated at only 6% cover of a whole page. Your guess is as good as mine what are you coping mostly black/dark copies? it will be used up quicker.
Mar 09, 2008 | Sharp AR-153E Copier
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
