Question about Canon MP490 InkJet Printer
My Canon MP490 is jamming on every print job, and I've tried about 20 or so in a row. It does the same thing each time. If you were facing the printer, the left side of the paper comes down before
pineworks
  • 4041 Answers
SOURCE: Paper jam in mp610
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 09, 2010
SOURCE: My printer grabs the paper sideways and feeds it
Sounds like my Canon MX330... It's a mfg defect... I guess I now know why they were cheap at Factory Direct.. ***
Posted on Jun 25, 2010
Inky
  • 691 Answers
SOURCE: Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Posted on Oct 14, 2007
CuLeBrO
  • 54 Answers
SOURCE: paper jam message
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Posted on Mar 02, 2009
SOURCE: The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Posted on Apr 05, 2009
Had paper jam and will not print
switch off and unplug the unit. open the cover and remove all paper inside. Be careful not to damage any bits inside, Canon is fairly fragile unfortunately. switch pc off, reconnect printer and restart both, it should print hopefully.
May 31, 2015 | Canon MP490 InkJet Printer
MP490 driver download to Vista PC
Do a file search for Canon, you may see the missing Icon and can "copy to" your Desktop
Apr 21, 2013 | Canon MP490 InkJet Printer
Canon printer won't print wirelessly
You should call on ((+1-800-585-2494 )) Toll Free Canon and get help for Canon.
Toll Free Number.
Oct 24, 2012 | Office Equipment & Supplies
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
We have a canon MP490 printer, and it says that there is a paper jam, but there is not. We have tried everything we can think of to fix it, including unplugging it, but it hasn't worked.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 31, 2011 | Canon MP490 InkJet Printer
I have a canon printer and it says paper output slot is jammed and we don't have any paper jammed?
WEll, take it apart and look for tiny paper shreads stuck somewhere...then unplug power for at least 60 sec. and try again.
Sep 06, 2010 | Canon Office Equipment & Supplies
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
I have a canon pixma mp490 all in one printer and am out colored ink how do i switch it over to be just black and white prints
Constantly get paper jam message while there's no paper jammed.
Is there a solution for this problem?
starinthesky69@hotmail.com
Michael Odor
Feb 04, 2010 | Canon MP490 InkJet Printer
Hello,i want to ask-how reset canon mp 490 ink cartriges level,or how reset the printer?sorry for my english
I tried pressing the OK button for 6 seconds, while holding it press the red stop button and hold it until the LCD refreshes.
Nov 04, 2009 | Canon Office Equipment & Supplies
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon MP490 InkJet Printer Logo
214 people viewed this question
old marine
old marine
