Question about Sega Genesis Console
Sega Genesis 3 has horrible sound quality.
I bought one off eBay a few days ago and it came in the mail yesterday. Everything works fine except for the sound, which is awful. I made sure it wasn't just one game either, it does it with every game I try. The sound is very scratchy, and sometimes just goes quiet for a few seconds depending on the situation. It's hooked up to the TV with the RF switch that came with it (says SG RF UNIT on it and states that it is for the Genesis), and I'm also using the AC adapter that came with it. If anyone is wondering, the video quality is perfectly fine, it's just the audio that has problems.
  • 291 Answers
Well it could be that the av cables or the rf switches which ones you are using might be having problems so try a new av cable or rf swtich to see if it makes a difference. If still the aduio is not work there might be an internal issue with the console that should setup a red warning flag like the sound part inside of the console is broken then.
6 STARS IF THIS SOLOUTION IS HELPING.
Posted on Mar 16, 2012
3 Suggested Answers
  • 20 Answers
SOURCE: no picture for Genesis - RF or console?
The problem is most likely not the console. The first thing you should try is cleaning the contacts on your games. Most of the games have tamper proof fasteners so unless you have the right tools you won't be able to open them. You can take a q-tip with a little alcohol (damp not wet) and clean both sides of the circuit board on the cartridge until the q-tip comes out clean. Let it dry before sticking it into the console. If you do this to a couple of games with no luck try taking an emery board (for fingernails) and gently inserting it into the connector in the console a few times all along the length of it. Make sure to only push it straight in and pull it straight out. If you try pushing it side to side while it is in there you could damage the connector.
Posted on Dec 08, 2007
  • 69 Answers
SOURCE: Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Posted on Sep 23, 2009
Sega Genesis Model 2 won't turn on
Well it sounds like that you have a bad ac adapter then so buy a new ac adapter the console is fine so just a new adapter that's all.
Apr 28, 2012 | Sega Genesis Console
I bought a Sega Genesis Model 1 from a thrift store, and everything works great, but it looks like some one has turned the darkness up on my tv when i play games. I tried it with both the genesis RF and an...
Hi, get your hands on a new AV cable you will notice a great difference in picture quality compared to the RF switch. see www.gameoz.com.au as they stock the cable you require. They also can modify the console with a s-video out put which would be one of the best picture quality possable available from one of these retro consoles
Sep 16, 2010 | Sega Genesis Console
Sega Genesis Video Problem
Maybe you are supposed to be on Channel 4. There should be a 3-4 switch on your RF adapter. Try wiggling the video connection in the back of your genesis and see if that fixes anything, it might be a lose port, in which case you have to wrap the cable underneath the genesis or something heavy to keep it at a working angle (if you find a working angle).
It is also possible your RF cable is bad. They aren't that much on ebay, but make sure you buy one for your model (there are 2 models of genesis and they use different RF cables)
I hope this helps somewhat.
Jan 07, 2010 | Sega Genesis Console
Bad picture with Sega Genesis model 1
Taking your problem in a whole new direction, why don't you try purchasing an 8 or 9-pin (depending on the type of Genesis you have) DIN RCA cable. This will improve picture and sound, and you won't have to worry about malfunctioning RF converters. Your problem sounds like the RF adapters are inadequate.
Sep 16, 2009 | Nintendo Super NES Console
Power, But No Picture!
Try moving the a/v or rf cable in the back of the genesis
Mar 03, 2009 | Sega Genesis Console
Games Will Not Save
Usually, there were battery backups in the cartridges, not the console. If you can get the cartridges open (usually a tool can be found on eBay for a few dollars) you can replace the lithium battery inside. You might want to leave the game in with the console going first-some of the batteries would recharge that way, but it's unlikely-the battery is at the youngest 11 years old.
Feb 18, 2009 | Sega Genesis Console
Slight picture, no sound
sounds like you might have 1 of 2 problems
1 you need to fine tune your tv correctly
2 the lead you have may be worn and have a poor signal coming through
Also you might like to upgrade to an RGB Scart
www.retro-cache.com
You will end up will a far better puicture
Jul 28, 2008 | Sega Genesis Console
Line across top of screen
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
How to clean the contacts inside the Genesis.
Honestly, especially with those older consoles, I wouldnt trust any type of liquid with it.
Mar 10, 2008 | Sega Genesis Console
Sega genesis works but has no sound
ya proably bad cable u can go on ebay order new cord ok
Feb 08, 2008 | Sega Genesis Console
Sega Genesis Console Logo
105 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
