Philips 60pp9202 schematic
Hi! Do you know where I can find a wiring schematic for a philips 60pp9202 ?
  • 7 more comments
  • Michelle888 Oct 26, 2008
    Apparently all of my orginial post did not come through ... I have a convergance issue. I figured out (I think) what parts to replace and ordered them. I labeled everything before I took it apart but some how some of my marks came off and I'm not 100% sure what goes where now. I did my best and hooked it back up, but now I have NO picture at all and it smelled like something was burning. Great. So it's unplugged again and I'm guessing a wiring schematic is what I need now?
    So what do I do now? I've never used this service before ... if i click on accept your solution then it means my problem has been solved right? So if it's not solved, then I'd have to pay to write back in?
    And if I don't click on ask other experts ... then does the problem just stay in your queue or can another expert still chime in?
    Thanks but the link provided does not address my issue. That picture is for how to hook up components to the set ... I need a wiring schematic for the actual inside of the set ... where all the parts are that I've replaced.
    My TV is a Philips 60PP9202/17F. I am looking for an INSIDE wiring diagram schematic. I have a convergance issue. I figured out (I think) what parts to replace and ordered them. I labeled all wires/connectors before I took it apart but some how some of my marks came off and I'm not 100% sure what goes where now. I did my best and hooked it back up, but now I have NO picture at all and it smelled like something was burning. Great. So it's unplugged again and I'm guessing a wiring schematic is what I need now?
    I'm sorry, I could not see your complete reply before I reposted. I will check out the manual and let you know. Thanks again for your time.
  • Michelle888 Nov 20, 2008
    Still having convergance issues. I replaced the 2 convergance ICs, all the resistors and I inspected the board for cracks, etc.. but didn't see any.
  • Michelle888 Nov 23, 2008
    Still having convergance issues. I replaced the 2 convergance ICs, all the resistors and I inspected the board for cracks, etc.. but didn't see any. What else can I do?
    Hi! I have found the manual and have replaced the parts listed above. However it did not fix my convergance issues. What else can I do to fix the convergance issue?
  • Michelle888 Nov 24, 2008
    How can i figure out if I fried it? Is it expensive to replace?
  • 147 Answers
Sounds like you mite have fried the membrain carbon board
Posted on Nov 24, 2008
  • Joshua Davis Nov 25, 2008
    did it smell like sumthing burning
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I have to ask, do you have the service manual or at least the schematic diagrams? This is essential to proceed with the diagnosis. If yes, then what is required is to check for the presence or absence of certain voltages at key points. The service manual and/or schematics would direct you where and what reading. The normal procedure would be to check first the area where you originally worked on to double check that what was done before is not contributing to the current issue. Special attention should be given to the solder of the pins of the STK ICs. Thereafter, voltage measurement which would require a live set. If the unit will not come on, are there any blinking lights? If yes how many or is there a sequence? If none, then diagnosis/check shold move to the power supply section.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
  • Louie  Role
    Louie Role Nov 23, 2008
    Appreciate the immediate postback. A request for additional info pls:
    • since parts have been replaced, have you made the necessary alignment? This would be described likewise in the manual;
    • If it will not align, have you checked that the voltages are correct at the proper pins or checkpoints?
    I am assuming that the unit powers up, there is video and audio and it is just that the video/display is the issue. Additionally, would it be possible to post an image of your display/video to ascertain probable problem.
    Cheers.
    Novelist:
  • 98 Answers
Below are two links that should take you directly to philipselectronics.com to download the original users manual for your TV in .pdf format. Hopefully, this will help. Have a nice evening!
James
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=ZZCA_TV_GR&sct=ZZSU_TV_GR&session=20081123183914_24.166.2.117&grp=TV_GR&ctn=60PP9202&mid=Link_UserManuals&hlt=Link_UserManuals
http://www.p4c.philips.com/files/6/60pp9202/60pp9202_dfu_aen.pdf
    Genius:
  • 1,011 Answers
Sir,
Click this link for more information
http://www.fixya.com/Brands/Manuals/P/Philips/60pp9202_60_e20ad8129282e9dcc188e820d3f697c3/images/1A05FF1C5FDE87166710FD543F39CB05.png
thanks
good luck
Posted on Oct 26, 2008
  • 13,433 Answers
Can you confirm the model of your philips? dptv310? for example
  • 2 more comments
  • Ekse Oct 26, 2008
    you can email pfc_dressler@cox.net state that you have philips 60pp9202 and you need the service manual. you should get it from there, its 1770 pages
  • Ekse Oct 26, 2008
    you can still come back to this page and write more comments if you need further assistance.
  • Ekse Oct 26, 2008
    I would get a email stateing that theres a new comment and I would read it.. I emailed the person myself, hopefully we will get the service manual with the diagrams from there, if not Il look for another.
  • Ekse Oct 26, 2008
    Hello? Can you tell me the model number? also can you give me your email so I can send it to you ones I receave it?
    Also accept my solution so I know your able to read my comments and you want my support if you don't then accept someone else(ginko) or don't accept anyone at all.
  • 19,396 Answers
Hi, I can see if I find the service manual, that will take some time.
  • Ginko
    Ginko Oct 26, 2008
    Hi there, the service manual is not available for free download, I still recommend buying the manual if you want to carry on with the repair by yourself. Here is the link for buying the repair manual
    Link to service manual seller.
    Regarding the convergence issue, when you have convergence problems, usually you find out that you need to replace the two convergence ICs.
    You can test convergence ICs but checking continuity on the pico fuses located at the base of the ICs.
    Your TV set mounts STK 392-110convergence ICs, this can be replaced with STK 392-120, that are more resistant.
    You can bay replacement STK at any electronic components store.
Hi my tv makes a chirping sound? it a philips 60pp9202 any ideas?
Bad High Voltage Generator. Part is No Longer Available. I need one myself. I saved the chassis for spare parts.
Dec 10, 2010 | Philips 60PP9202 60" Rear Projection...
I have a philips 60pp9202/17f and it will not turn on
My Philip 60PP9202/17F...my tv will not turn on. What is the most common problem?
Apr 03, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
60pp9202/17f no picture after IC instal
double check the IC pins to be sure they are all soldered without any bridging and then doublecheck your wire connections
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips REar Projection Television model 60pp9202/17F
Hello maylynnhurd post me the problem you are having with you set and ti get the schematic for this television you may have to look on line for it or contact Philips directly for that.
Aug 20, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202/17F Projection Television
How old is this tv?
Projection tvs are all basically the same. Most likely it is the coil unless you can find a short somewhere else in the power supply. The coils tend to go after so much use. If you still want to email the schematic, let me know but I think you are right with thinking that it is the coil and it will need to be replaced.
Let me know if you have any further questions as I would be more than happy to answer them for you
Jun 09, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60 in.
sound like your convergence amps are blown. also known as stk's
Dec 19, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
