Question about Miele W149 Top Load Washer
Leaking miele w149
Hi, I have a Miele W149 top loader. It starts leaking water as soon as I open the water faucet (It's outside on the balcony so I turn it off and pump it empty when I don't use it) I removed the top and left side plate. The leak seems to be somewhere behind the soap dispenser, underneat the hoses connecting the watersupply to the soap dispenser. It is not one of the hoses, and I can't really see where it is coming from. I have already cleaned and checked all filters and the soap dispenser tray & inside.
  • 1 more comment
  • Tim K Feb 18, 2012
    Also, still a small amount of water comes through the soap dispenser.
  • Tim K Feb 19, 2012
    It seems to be where the waterhose comes in, and splits into 3 smaller hoses towards the soap dispenser. Is this the pump and how do I reach it?
  • Tim K Feb 21, 2012
    Problem Solved:
    The inlet valve was leaking. The plastic cover had ruptured. I removed it, and replaced it with a 2nd hand original Miele part. Had to take almost half the machine apart to replace it though.
4 Suggested Answers
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
  • 82 Answers
SOURCE: water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Posted on Jan 16, 2010
SOURCE: Flashing start light
Hi, I have the same problem. Did you find a solution?
Posted on Dec 27, 2010
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
I have a Miele W 487 WPS front loader washing machine which is about 6 years old. The machine has started to leak (a trickle) water whilst in operation. Is it fair to assume that this would be due to the...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jul 20, 2011 | Miele W487 Front Load Washer
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
What can I do if the drainage red light comes on?
In most cases, Its simply the lid switch that has gone bad.
Put your washer on Spin cycle and look for the little plastic peice on your lid that goes into a small opening, if you have this then verify its working by pushing a small screwdriver in the hole, pressing it down.
The washer needs to verify that the lid is closed before it will go into spin mode (Safety for peoplesw hands etc).
If you dont see this then you may have a magnic type switch or one built into the lid itself.
Most local appliance parts stores have this part with a model and make of the washer.
Good Luck!
Nov 04, 2009 | Miele W149 Top Load Washer
Water runs through the waterpump and down to the floor when i start my Miele Novotronic W149
it sounds like the waste pipeis too low lift it up more and thisshould clear the problem
Dec 21, 2008 | Miele W149 Top Load Washer
Oct 29, 2008 | Miele W149 Top Load Washer
Miele W149 Top Load Washer Logo
101 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
