Question about Panasonic DMC-TZ4 Digital Camera
Poor picture quality. It almost looks infrared.
In any picture mode, the picture and screen has lost color definition and clarity. It almost looks like it was in infrared mode. I can barely make the picture out on the screen. After a couple seconds my camera tells me to "Please turn camera off and then on again". This happens every time. It seems like something is wrong with the lens because the menu and other operations look fine. I am not sure what caused this to happen. I haven't dropped it or gotten it wet in any way. please help!
    Master:
  • 383 Answers
THe CCd is the problem ..... you will have to get it repaired or replaced ......
Posted on Oct 26, 2008
We connected everything last night and the picture lacks clarity.
Is this a new television? You say you connected everything and it lacks clarity, are you saying you connected high definition devices (ie: Bluray player) and the picture is not in HD? Are you connecting thru HDMI? Sometimes it could be cables, could be that you are using A/V or S-video and the quality won't be as high. Are you connecting directly or thru an audio receiver? Need more information.
Sep 01, 2015 | Televison & Video
AOC PD4264 Screen fault
Extremely blue color temperature that cannot be adjusted; some false-contouring artifacts in dark scenes; no picture-in-picture; limited connectivity with just one DVI and no HDMI inputs.
If use as a TV monitor:
The number of colors you can display is controlled by the video card installed in your computer. In order to display more than 16 colors, the proper video card driver must be installed. Contact your computer or video card manufacturer to obtain the latest driver from them.
If you are watching standard-definition or Cable/RF signal on an HDTV, the picture may appear to be of poor quality. This is because the TV is designed for viewing HD or at least digital content. Your best bet would be to upgrade to a Dish Network HD receiver and connect it to the TV with an HDMI cable. Similarly inputting analog signal to TV from your DVD player will not appear to be of great quality. A newer DVD player would most likely have component video output which would look much better. To get even greater quality, an upconverting DVD player connected with an HDMI cable would look the best. You could also upgrade to a Blu-ray disc player, which is capable of playing HD Blu-ray discs as well as DVD's at higher resolution. A less expensive choice could also be a streaming media box. Hierarchy of inputs for good picture quality:
Apr 13, 2012 | AOC A42HD84 42 in. Plasma HDTV
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Bad picture quality. all pictures look almost faded. Recently installed printer. Not sure if more software is needed. Using default settings but the print out qualities are very poor.
please clean your printer service mode or print option if you are not success see you print option resulation
change your color cartridge
Aug 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Jun 01, 2008 | Televison & Video
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Panasonic DMC-TZ4 Digital Camera Logo
95 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
