Question about Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax
Gestetner copier duplicate image on page
My 1980 gestetner 2201 copier has started to lay down a second image approximately half way down the copied page. It is a duplicate image of the original, but somewhat lighter, and you can see it on the lower half of the page. Any ideas re: blade problem, or new drum??? thanks for any help
    President:
  • Gestetner Master
  • 990 Answers
Replace drum blade
Posted on Dec 15, 2008
Copies come out with a duplicate lighter image half way down the page
Most of the time it's the fuser. Measure or mark edge to edge and make a tube. That's the size of the round part making the defect.
Jan 21, 2016 | Savin 2513 Black Toner Cartridge Genuine
Are there cleaning sheets for Sharp SF2414 duplicators?
Hello Paul,
There are no "cleaning sheets" for this unit. Typically when this unit starts leaving marks on printed copies then it is time to do some maintenance on it. By maintenance I mean replacing the imaging drum, the toner and or the developer, all of which can be ordered from this link; Sharp Monochrome Copier Copier Duplicator FREE delivery If you don't feel comfortable then you need to call service!
Mar 04, 2015 | Sharp Office Equipment & Supplies
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Every time I use my Gestetner to copy, copies come out with lines near the bottom of page.
first you take one print out from your computer see weather the same lines is thir or not if you find the that the print out is good you have to cleane the opticus (Eg. exposer glass reflector 1st mirror 2nd mirror 3rd mirror) - thanks
Mar 12, 2011 | Gestetner DSm615 Digital Imaging System
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
A copy with a lighter image of the copy on the page
Do printed pages come out better than copies?
If they are the same, you may try another toner cartridge (especially if it is a remanufactured or compatible toner), otherwise, you need your optics cleaned (mirrors and lens under the contact glass)
Mar 06, 2009 | Canon Office Equipment & Supplies
Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax Logo
100 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
