Question about Kenmore Dryers
I need to replace the thermal fuse on my kenmore gas dryer, model 110.74892401. Should I go thru the front panel and remove the drum, or can I remove the back panel? It looks like I will have to remove the gas line to take off the back panel.
  • 3 Answers
SOURCE: kenmore gas dryer
It could be the ignitor, you have to open the dryer, take the belt off and start it, if you dont see a red glowing light could be the igniter, you have to disconect it and check for voltage, if you have voltage, replace the igniter
Posted on Dec 16, 2007
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 04, 2009
  • 744 Answers
SOURCE: either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Posted on Mar 29, 2009
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Posted on Oct 08, 2009
Kenmore elite 110.7703 no heat
Hi there
From the model number it seems this machine was made by Whirlpool for Kenmore. The thermal fuse is on front bottom near the blower wheel.
a) Pop open the front panel.
b) Then remove front door panel by removing the two secrews
c) Remember to disengage the door switch wiring
d) you will see the thermal fuse near the blower compartment.
e) If thermal fuse is burned out then it should not have continuity on OHMS scale on a multimeter.
Dec 07, 2013 | Kenmore Dryers
WHERE IS THE THERMAL FUSE ON A MODEL 97589210 75892 GAS DRYER
What thermal fuse. Are you talking about the one built into the drum motor, that is not user replaceable, short of replacing the motor.
Jan 17, 2011 | Kenmore Dryers
80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Mar 28, 2010 | Kenmore Dryers
Gas dryer will not heat up kenmore 80 series heavy duty 72822
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 21, 2009 | Kenmore 72822Gas Dryer
Kenmore dryer # 60622 dryer runs fine but no heat. what will be the list of problems ?
Jun 20, 2009 | Kenmore Dryers
KENMORE GAS DRYER DOES NOT IGNATE MOD# 87980800
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer will not start
i would check the thermal fuse on the back of the dryer where the vent come out remove the back panell it is a small white with2 blue wirs most of the time and one screw holding it in un less you dryer does not have a removeable back then there is a removable front cover acrose the bottom remove it and the fuse is on the blwer housing the in the front should look the same and described above.
Jan 19, 2009 | Kenmore Dryers
Drum very difficult to turn manually. not spinning with ac on
If your trying to turn the drum from the inside, or by opening the top and trying to turn, there will be some resistance.
What are the symptoms of your problem? Does the drum not turn when the dryer is turned on (with or without clothes)?
If so -
1) the idler roller could be bad
2) The motor is bad
The motor is internally thermally protected and no thermal fuse is used outside of the motor. Only place a thermal fuse is used is to prevent overheating.
Provide more information to you problem.
The lower front panel is not removed to service this unit. All service is done from the top or rear.
Jan 15, 2009 | Kenmore 659 Electric Dryer
Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Dec 13, 2008 | Kenmore 63942 Dryer
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
