Question about Sony FD Trinitron WEGA KD-34XBR2 34" TV
Ilink Menu continuosly popping up
The menu keeps appearing on the screen "trying to connect to i.link" or some version of this. I have removed the batteries from the remote, taken it to a different room, turned the tv off for a couple of months nothing is working and I cannot find a tech to come and look at it. HELP!
  • bassfuser Dec 31, 2008
    The Ilink menu pops up for no reason. I've tried turning off the TV overnight, but problem persists. Seems to be worse at times leading me to believe there may be some external interference.
    Any ideas?
    Thanks.
Maybe. It appears that there may be a bad connection. Probably a bad solder joint. The problem started after I moved the TV. Today I was a little frustrated and jarred the TV pretty good while moving it. The problem went away and hopefully will not return. When and if it does I guess I'll have to check internally for a bad connection.
Posted on Dec 31, 2008
On my technika TV menu screen keeps popping up,how can i stop this?
problem seems to be solved,i altered the auto time feature and it settled down
thanks for replying
Bob Hawksby
Mar 31, 2014 | Audio Players & Recorders
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Describe how to update blue ray player
Software Update Instructions
    • WARNING!! Do not power off the Home Entertainment Server or disconnect it from the AC power outlet. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • WARNING!! Do not press any buttons, except as instructed, until the update is complete. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • The software update process usually takes about 15 to 30 minutes, depending on system configuration and network connection.
    1. Power on the television and make sure it is tuned to the inputs to which the HES-V1000 Home Entertainment Server is connected.
    2. Connect the LAN terminal on the HES-V1000 to your Internet source using an Ethernet cable.
    3. Power on the HES-V1000 Home Entertainment Server.
    4. Press "HOME" to go to the Home Menu.
    5. At the "Home" menu, select "Settings".
    6. At the "Settings" menu, select "System Settings" and then press "ENTER".
    7. At the "System Settings" screen, select "Software Update" and then press "ENTER".
    8. At the "Software Update" screen, select "Network Update" and then press "ENTER".
      Note: The network connection display appears.
    9. Select "Yes" and press "ENTER".
      Note: The server starts to check the version information.
    10. At the version confirmation screen, select "Yes" and then press "ENTER".
    11. The software License Agreement appears. After reading the content, select "Agree" and press "ENTER".
    12. The software update is downloaded and automatically starts updating the HES-V1000 software.While the software update is downloading:
      • "DOWNLOADING XX%" appears on the front panel display, indicating the progress.
      • If the download fails, an error message appears on the screen, and the display returns to the Home Menu.
      When the software update is complete:
      • "VERSION UP FINISH" appears on the front panel display, indicating that the update was successful.
      • If "VERSION UP FAIL" appears on the front panel display, repeat the update procedure above.
    13. The system will power off automatically.
    14. Power on the Home Entertainment Server again.
Please refer the following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5321&mdl=HESV1000
Feb 11, 2010 | Sony HESV1000 200 Disc Blue-Ray Server
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
Config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Dec 07, 2008 | Acer AL1912 19" LCD Monitor
Menu 42PF9630A 42
go to www.ceusasupport.philips.com and upgrade your televisions software to the latest version. this is a very common issue.
Jan 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony FD Trinitron WEGA KD-34XBR2 34" TV Logo
182 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
