Question about Microwave Ovens
Microwave keypad is locked
My microwave keypad is locked. I can see the time, but when I push a button it says the it is locked. How do I unlock the microwave? key pad is locked
  • jp2cmp Oct 27, 2008
    my keypad is locked, I can see the clock but nothing workes. This started yesterday and then it turned on by it'sself after an hour or so. This time it has not turned back on
  • jdcomau Oct 29, 2008
    kenmore profile is locked
3 Suggested Answers
SOURCE: microwave keypad is locked
Touch and hold START more
than 4 seconds. "L" will
disappear and you hear two
beeps. At this time the oven is
ready.
Posted on Aug 23, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: key pad lockout and load beeps
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
Since it's a basic counter top microwave, this may not be worth repair when you consider the cost of a new comparable unit.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The part number of your keypad is
WB27X10624 and you can get it here for $51.37 plus shipping.
Posted on Dec 27, 2009
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
PLATE NOT ROTATING AND THE KEYS NOT FUNCTIONING
If keypad is locked, hold down clear button for 3 seconds to unlock keypad.
May 12, 2010 | GE JVM1542 Microwave Oven
Key pad lockout and load beeps
Dec 27, 2009 | GE Countertop Microwave Oven
ready.
Jul 29, 2008 | Goldstar MV-1615 Microwave Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Power is on, but won't cook
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display. You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key. If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call LG / Goldstar customer service at 1-800-243-0000 to find the nearest authorized servicer. There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad. Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean. Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic. If this is what has happened, it would not be covered under warranty, and it may or may not be repairable. A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out with an air compressor or heat, but often that does not work.
Nov 10, 2006 | Goldstar MV-1615 Microwave Oven
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
Sharp R-1441
There should be a "CUSTOM HELP" or "HELP" pad on the keypad. When you press that, "CHILD LOCK" should be the first option. The display will guide you to press 1 or 2, etc., to turn it off. We don't have an online copy of that manual, but it's part number TINSEB114MRR0 (zero on the end). You can order it via Tritronics at http:/www.wehaveparts.com
Oct 04, 2006 | Sharp R-1871 Convection Microwave Oven
Microwave Ovens Logo
279 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
