Question about Canon PIXMA iP90 Mobile Printer
Printer error 5C00
How do reset or repair. It started with a piece of paper jammed in the computer - which I removed. I had to slide the printer head over to get at it. Randy
  • 37 Answers
UNPLUG PRINTER,AND WAIT 5 MIN,PLG BACK IN AND IT SHOULD RESET ITSELF
Posted on Feb 18, 2012
manojro
  • 495 Answers
SOURCE: error 5c00
check in inside the fusing unit by the roller.
Posted on May 12, 2009
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
michael_grey
  • 365 Answers
SOURCE: MP610 PRINTER ERROR 6A00 LIGHTS FLASHING
You can try to reset it back to factory by removing the printhead and all cartridges.
Power off the unplug from wall for 30 min.Reverse procedure and see what happens.
From what I am reading is the carriage will not lock on the left!
Correct?
Try this and let us know.
Posted on Aug 15, 2009
  • 56 Answers
SOURCE: i have d760 cannon copier. finally removed the
hi,
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Posted on Oct 24, 2009
Semi-Driver
  • 434 Answers
SOURCE: Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
Posted on Dec 28, 2009
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Welll its not a canon but ew are in dire need. Our 16 month old OKI b4600 wont print.Error message says clear paper jam. cant find a jam swapped tray, cartridge/drum etc. No luck. Any suggested
Hi There and Welcome to Fixya,
Usually, paper jams can occur at the input location right at the bottom of the printer - always remember that even a tiny piece of paper can cause halt in printing, hence, the error message.
Here's what I'm suggesting for you to do :
  • Start with pulling out the tray from the printer and look for ANY crumpled/pieces/fragments of paper that could be tucked in.
  • At the bottom of the printer is the feed area - do the same thing and remove any pieces of paper.
  • Ensure that it's absolutely "paper fragment free" before returning the tray back at the printer.
  • Next, is to open the top cover and carefully remove the drum.
  • Remove any pieces or fragments of paper that you find.
  • Carefully slide back the drum, ensure that everything snaps into place.
  • Close the top cover.
  • Restart your printer.
I most certainly hope this helps.
Thank you for using FixYa.
Mar 25, 2011 | Canon PC-940 Black and White Copier
Error message 5C00 on screen, machine wont print or copy after cartridge fill, its a pixma mp 550 in spain looks like the 640.
Error 5c00 is classified as a purge unit error. The purge unit is a device in the printer that refreshes and cleans the ink cartridges. This error message occurs when the printer's purge unit is not able to complete its cycle fully.
Several issues can prevent the purge unit from cycling completely. Paper or debris may be caught in the purge unit or it may have become stuck out of place.
How to fix it:
1) Turn the printer on and open the cover.
2) When the carriage has moved to the center of the printer, disconnect the power by removing the power plug from the back.
3) You should now be able to slide the carriage gently to the left, which will give you access to the purge unit located on the right side of the printer.
4) Inspect the unit for any jammed debris or stuck pieces. Using a paper towel, gently move any jammed pieces back into place.
Mar 04, 2011 | Canon MP560 All-In-One InkJet Printer
Ive got a pixma mx700 printer and im getting the 5c00 error how do i get rid of this
Error code 5C00 refers to possible paper jam or product needs reset or service.
It is possible that a previous paper jam has left a piece of paper inside the machine. If you cannot see any paper jammed at either input area, open the rear cover and look in there. Otherwise, you can try to reset the product:
Reset the printer:
If all of these suggestions fail, your MX700 may require repair service.
Dec 28, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Purge unit error 5c00 4 flashes
Reset will not clear a purge unit error. Sometimes you can remove the purge assembly and clean out all the ink covering the moving parts. You clean with just water, most times I just replace the purge unit, around $30.00
Dec 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
Error code says 5c00 on my canon pixma mp500 printer. cant find my manual to figure out what the code means
The error code 5c00 usually means that there is a paper jam or paper path restriction.
If the path is not restricted, the printer will need servicing.
If you want a downloadable user manual for your printer go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11995
Dec 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
5c00 error
Error 5C00 is Purge Cam Sensor error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need repairing.
Nov 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Mar 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
75 people viewed this question
old marine
old marine
