Question about Honeywell Heating & Cooling
HRDP8 Lost Admin Passwords RESET FIRMWARE?
I have taken over in a job and the previous person has changed admin passwords from default, they can not be contacted and I cannot access the setup menu's I need to know how to reset the passwords or reset the whole unit to factory software, I tried removing the batteries and i have reflagged the firmware but it kept the edited user and passwords, anyone know how i can do this without sending it away to honeywell?
RickOz
  • 145 Answers
SOURCE: Lost Admin password for SSL-VPN 2000
This is as close as I can come.
http://www.sonicwall.com/downloads/SSL-VPN_2000-4000_2.1_Release_Notes.pdf
Posted on Apr 10, 2009
  • 148 Answers
SOURCE: Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
Posted on May 10, 2009
  • 116 Answers
SOURCE: how to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
Posted on May 15, 2009
ted1430
  • 339 Answers
SOURCE: i forgot the password and cannot access the web interface
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Posted on Jul 12, 2009
SOURCE: default factory pass fails while cannot be reset
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
If you have problem in access router then you need to reset all settings to defaults then you can access it with above method.
For that press RESET button for 10 seconds it is in back panel of router.
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Posted on Nov 22, 2009
What is the password for a belkin router F9K1123v2
If you are asking what the default credentials are to log into the admin panel of the router, then the options are below.
Default usernames: admin, Admin, [blank]
Default passwords: admin, password, [blank]
If you are asking for the Wi-Fi password, that is unique to the user who initially set it up. You can reset the router but following the manufacturer instructions and holding the reset button down in the back. This will erase all settings on the router.
Mar 14, 2017 | Belkin Computers & Internet
How to change bt password wireless
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Apr 29, 2014 | Computers & Internet
This router was previously used by my sister-in-law in manila...then i brought this router in japan...when i want to install it in my computer i cant access on the site that written in the...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Computers & Internet
NEED TO UNLOCK PASSWORD IT WAS PRE OWNED
Routers has reset button located at the back. You have to use a paperclip to push it. This will reset the router into its default settings.
Defaults passwords can vary depending on the model or firmware. You can refer to the manual for your default passowrd
Usually its username/password: admin or username:admin pass:blank.
Jul 24, 2011 | Computers & Internet
Cannot connect to the router lost the password
There are two passwords for the router: the WEP/WPA password, which lets you connect to it wirelessly; and the admin password, which lets you change the configuration. If you have lost the WEP/WPA password but know the admin password (or haven't reset it from its factory default), you can connect a temporary cable between your router and your computer, and use the Easy Install Wizard or the manual configuration steps (see manual) to change the WEP/WPA password to something you know. If you do not know the admin password, then you have to reset the router to factory defaults by pressing and holding the Reset button for at least 10 seconds, and then using the Easy Install Wizard to configure it again from scratch.
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Apr 13, 2009 | Computers & Internet
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Heating & Cooling Logo
46 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
