CD PLAYER ON MY HITACHI AXM898U DOESNT READ THE CD
CD DRAWER SEEMS TO NOT CLOSE ALL THE WAY AND YOU HAVE TO PUSH IT IN. THEN IT DOESNT READ THE CD AND OPENS AGAIN.
4 Suggested Answers
martyfarty
SOURCE: SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Posted on Jan 21, 2009
supertech6
  • 513 Answers
SOURCE: when dvd is inserted "read" comes up on screen on
Not a lot to go on...
I would expect the unit says read for a while, then opens the drawer. This is an optic issue. Optics are $$$. If the drawer opens almost immediately, it is likely the drive's drawer sense switch needs cleaning.
Posted on Mar 29, 2010
Testimonial: "thanks"
ekcnoel
  • 998 Answers
SOURCE: My DVD-player does not read
if you open your unit you will find a black rubber connecting to a pulley under the drawer try to check it if theirs a spilled greased remove the grease and try to operate it if still the rubber is not holding try to replace it.
Posted on Oct 15, 2010
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Hitachi htc-c15u drawer wont open
straighten a paper clip and insert it into a small hole in front of the CD panel, this is an emergency eject button for a defective cd drive
Jul 14, 2014 | Computers & Internet
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
A cd is stuck in 5 cd player. Drawer won't close. (Sony) When drawer did open/close, it just started making a noise - maybe belt wearing out.
Without knowing the model number, this is pure speculation:
There are some Sony units that can easily get "out of time" in the loading mechanism. This can be caused by a broken trace in a ribbon cable or a defective sensor. Some models can get out of alignment or timing if you push the drawer rather than pushing the close button. Please update this with the model number, and I should be able to give you more details.
Thanks,
Dan
Oct 01, 2009 | Sony Audio Players & Recorders
Cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
Mar 16, 2009 | Gateway Computers & Internet
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
