My Stiletto II will let me program (schedule) recordings but when the time to record comes it doesn't record. I can manually get it to record if I'm around to push the heart shaped button. It used to work perfectly. I tried resetting to all factory settings but that didn't fix it.
If you’re having this problem while using the FM transmitter try using a different FM Station.I have the same problem.Mine only does this when I am using the FM transmitter.I recently noticed my volume is adjustable on certain FM Stations, and on other FM stations the volume control is limited. I hope this helps.
Just plug in the usb wire and wait a few minutes and see if new down load comes on your pc.Download it.You'll lose all recorded info.They say buy a new 1 when they're not sure whats up.Don't think many are trained.It's like a pc it bogs down .screws up.Needs up dates etc. union k
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
I'm a relatively new subscriber, only having my stiletto2 for 3 months. It just started "not recording" and "deleting my recordings". In researching, I came to this thread. Since no one really seems to have posted a real solution here, I'll share what I've found elsewhere.
1.) Check to make sure your SL2 has the latest software (ZAP). To find out what version you have, navigate to Settings >> Device >> Device Info. If your software is not up-to-date simply connect your radio to Internet Radio for about an hour and it will be downloaded. You will get a notice on your screen when the update is complete.
2.) Perform a Full Shutdown of your SL2 at least once a month by holding the power button down for 10 seconds. If you do a lot of recordings it's advised to perform a shutdown weekly or more for best results. This will flush the system, clean up and remove old and expired recordings/replays and reduce general screen lag. For some this simple step has eliminated missing recordings all together.
3.) Do not use your SL2 as an archive device and try to avoid using your internal memory over 50% for the time being. If you do a lot of recordings it's also advised to disable Radio Replays.
If 1-2-3 don't work, try 4
4) Set and Erase 4a. go into your Settings Menu>>Device>>Reset & Erase. 4b. As soon as you complete the process (Reset & Erase) and have rebooted, you will need to connect to Wi-Fi again to again download the baseband update. Let it run for at least 30 minutes to ensure that it is able to get the entire update. Then tune to Satellite Radio it SHOULD complete the baseband update. 4c. You should see the Updating SIRIUS message for about 7 minutes. If it's only up for a minute or two, then it may bet hat the update failed again. You can check the Service Info screen to be sure. 4d. If you then shutdown your SL2 (by holding down the power switch for 5 seconds) then turn it back on, it should complete the baseband update process.
Usually this is a signal issue and it happens when recording indoors mostly, right? The signal dropps but only for a second or two so when you look at it its fine. you've probably notived it cutting in and out when "live" from time to time. Use your signal meter built in to the device and find the strongest signal location. If that doesnt work or its not the problem, update the software. If that doesnt work try running the recovery software but only as a last resort because you'll lose your recordings.
SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure. The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Double check your signal strength during the time of day your recording sounds like classic signal drop. Could also be software issue or memory issue. As a last resort;
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
I have the same problem. Where you able to fix yours?
