Question about Sharp AR-M700N Copier
Error code on a ar-m700n L4-03
  • 92 Answers
SOURCE: sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Posted on Oct 06, 2008
  • 87 Answers
SOURCE: Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Posted on Jan 21, 2009
  • 118 Answers
SOURCE: CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Posted on Aug 28, 2009
sir fixalot
  • 146 Answers
SOURCE: AR M700N copier jams... trouble code H5-01
h5-01 error is five consecutive jams in the fusingg section. P*C* gets you into dervice mode thenn 14 for trouble reset. then execute and restart. check the fuser pawls for dull edges and breaks. also check roller tensioning system on fuser.
Posted on Oct 13, 2009
  • 255 Answers
SOURCE: Sharp ar -m351 Error codes L4-30
Main motor is being locked because of drive overload, check the drive system and make sure it is smooth especially the duplex area.
Posted on Nov 24, 2009
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
Change toner cart and error f2-00
well this is normally toner bottle gear is tight or micro electronic card is defected which you can see on toner cartridge but if them ok check socket where this micro card pin goes if connections r fine and u replace developer did calibration but still same prolem then u need to check the board if u have tested main board where toner connector goes jus swap hope fully will be ok let me know
Feb 22, 2014 | Sharp AR-M700N Copier
Call for services code : E7-80
Communication trouble
between the MFP control
and the scanner (MFP
control detection)
Communication
establishment error/
framing/ parity/ protocol
error
Follows the
communication protocol
specifications.
Communication error,
timing abnormality of the
communication data and
the communication signal
line
Dec 05, 2013 | Sharp AR-M700N Copier
Code f2 40
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
Aug 29, 2013 | Sharp AR-M700N Copier
Sharp AR M700N toner not fusing properly
your bushing at fusser unit is worn out
Jun 03, 2013 | Sharp AR-M700N Copier
ERROR CODE F2-31
F2-31 = Process Control Error.
This is usually just a dirty Image Density Sensor.
If you are able to remove the drum unit check that the Image Density Sensor is not dirty or blocked.
The IDS is number '7' in this image:
fmtx.jpg The error should reset just by switching the machine off/on. The machine will attempt a 'process control' Provided the sensor is OK the machine should work. If there is a large amount of toner dust around the drum and in the machine it would be worth vacuuming this out. Check also that you are using the correct toner.
Hope this helps
Jan 18, 2011 | Sharp AR-M700N Copier
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower...
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Feb 06, 2010 | Sharp AR-M700N Copier
Oct 13, 2009 | Sharp AR-M700N Copier
Sharp AR-M700N Copier Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
