Question about Dyson DC33 Bagged Upright Vacuum
Its stopped suction but the belt is fine
When you turn it on it makes the normal sound for 2 to 3 seconds then does a higher pitch whirring sound like the belt has snapped but the belt is fine ??
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulty with your DC33. The issue you've described with the brushbar sounds unusual, and we'd appreciate the opportunity to provide further assistance. If you give our free Helpline a call, we'll be able to determine what's causing the noise, and may be able to resolve this right over the phone.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it'll help if you have the machine to hand when you call, so we can run through some troubleshooting with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 20, 2012
My vacuum is making a loud whirring sound and is hotter than normal.
Hi Kelsey! I understand how frustrating this must be. Dirty filters or a clog can cause the vacuum to change sound and be hotter than normal.
Here is a quick link to troubleshooting the excessive noise:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Mar 28, 2013 | Bissell Cleanview Helix Bagless Upright...
I cleaned all the filters and it doesn't have any suction
Check the hoses for a clog. Sometimes the hoses themselves will get clogged and cut off suction -- other times it happens between the beater brush and the hose (within the cleaning head itself). If this is the case, when you turn on the vacuum it will make a higher pitch sound than normal, and sound like it is working really hard, even thought there is no suction. If you can't reach the clog, but you have found it in the hose, you can usually use a coat hanger to either loosen it up or remove it completely from the hose. If this does not work, you can try loosening the clog with another vacuum. Just use the second vacuum to reverse the normal air-flow through the hose ... sometimes this will loosen it up and get your equipment to work.
May 26, 2011 | Eureka 3276AVZ Bagless Upright Vacuum
The motor in the power head ran at a higher pitch for a for 8 to 10 seconds then stopped. If I push the reset button the powerhead may or may not start or it may start and run for a few seconds. The brush...
Did you check the belt? A broken belt results in lower strain on the motor, causing it to run faster resulting in the faster speed and higher pitch. This could result in overheating, which will cause the motor to shut off.
If this isn't the problem you'll need to take it to the nearest Aerus Electrolux store for trouble-shooting and repair.
http://www.aerushome.com/storelocator/
Dec 29, 2010 | Electrolux C101 Bagged Canister Vacuum
How much water goes in the vaccuum
I have a simular model. Here's what I do.
On the fill tank (that's the top tank), look on the front and you'll see where it says "Fill Line". Fill this with hot water first (so it doesn't foam up) and then add your cleaning solution. Make sure the lid on the bottom tank is on tight. It should snap in place. Top should also snap into place. Turn on and pull trigger and move forward a few feet, let go of trigger and solution will stop coming out. Do this a few times and then without pulling trigger, go over the same area you just did to pick up water. Repeat this until you are done. When the bottom tank is full, it will sound a little loader and higher pitch. Just empty tank and put back in and continue.
Hope this helps.
Sep 07, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Motor seems like it is overworking. The sound of the vacuum is higher pitched than before.
Hi!  Almost certainly your vacuum has a blockage somewhere. The higher pitch means the motor is running faster than normal, but it's not overworking, it's actually working less because it's moving less air.  Check for blockages and clear whatever you find (your user manual should tell you where and how to look), and that should be that! Alternatively, it may be that the drive belt to the brush roller has broken. Check that too. I hope this helps.  If not, please write again and I'll try again.
Feb 28, 2009 | Bissell 6591 Power Trak Revolution Bagless...
Belt constantly snapping
Make certain the belt is twisted the correct direction and that the brush is free to rotate. If the belt is twisted the wrong way it will probably come off or breake
Aug 30, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Dyson DC33 Bagged Upright Vacuum Logo
255 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
