Question about Freezers
Naiko ncf101 freezer not working at all.
There is power to it. Fuse OK. No noise from compressor. Occasional clicks as if it's trying to do something.
3 Suggested Answers
  • 122 Answers
SOURCE: the freezer quit working has power to theunit
If you hear a buzz or clicking sound, your compressor may be locked down, check warranty some have 5 year warranty on sealed system repair, parts and labor
Posted on Aug 28, 2010
walterkunesk
  • 683 Answers
SOURCE: buzzing noise from motor and
check my hints and you will find what your looking for.
Posted on Apr 21, 2011
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Freezer will not turn on, checked fuse to plug and wire seems to be ok. what else could it be
If it's a thermostat control, check power from thermostat to compressor. If power there, suspect relay or compressor fault
May 08, 2012 | Freezers
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
My freezer stopped functioning today. The light is on, there is a noise starting every now and then, there is a click and it stops. After a while the noise starts again. What should I do?
the noise you are hearing is probably the starting relay on the compressor failing and causing the overload protector to cut the power off to the compressor. Try replacing the overload and starting relay.
Mar 01, 2011 | GE 14.8 cu. ft. General Electric Chest...
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
The freezer quit working has power to theunit tryed turning it up it acts like a fuse or a relay the compressor is hot to the touch the compressor tuns on amin or so then turns off
Aug 27, 2010 | General Electric Upright Freezer...
My upright freezer works great but it makes a clicking noise like every thirty seconds or so.
These are the parts that would make a clicking noise. it is up to you to pin point where it is coming from:
compressor
timer
icemaker
fan
ok try to pin point if the clicking is coming from the inside or the outside
you can go to sears.com hit the parts link then enter the model number. you can view a diagram and it will show you where the parts are at
hope this helps
Mar 17, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
Mar 30, 2017 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
