Question about Bemis Home
Bemis toilet cistern lever
Seeing a new cistern side lever for a Bemis toliet , where ca they be bought from?
  • 88 Answers
SOURCE: I have a Bemis old toilet from 1982. How do I
on bottem of tank undo the plastic nut and itll come apartsame if replacing other seal
Posted on Aug 22, 2009
Testimonial: "Thanks!"
SOURCE: toilet keeps flushing itself, its
I have a Kohler Toilet K 3400 which has been leaking with a little stream of water entering into the tiolet bowl it self, I bought a Kohler replacement kit # 30166 ( one part that I did not replace in the kit was the part that has to be screwed in and removed by means of a Allen Key, only because it's hard to remove out ) and it leaks more then ever now and noisy let a lone wasting water too, I replaced the # 51230 Flush Ball also - adjusted the Float Ball for the water level - yet it keeps on having a stream of water entering the tiolet bowl - I would not like to buy the entire hardware it's self because it is costly -please have any Idea what to do ? Thank You Andy !
Posted on Nov 01, 2009
57 varieties
  • 1653 Answers
SOURCE: this bemis toilet flushes at least three times
A common problem. You have a partial blockage. If you have a plunger then you may be able to force the blockage out by filling up the bowl near to the top with warm water anbd filling it wit 4oz / 100ml liquid bleach and leaving it for 1 hour (not hot as this may crack the toilet). Then then plunge down several times until the blockage disappears. You may have to repeat this two or 3 times to completely clear the blockage. Also try filling up the bowl with pan with 10oz / 250ml liquid bleach and leaving overnight withthe lid down and the bathroom door shut. If you do not have a plunger use an empty 2litre or 80oz coke or plastic bottle, with the tope securely screwed on to maintain the rigidity of the bottle, so it will neatly fit the toilet cavity at the bottom without damaging the toilet.
Posted on Nov 08, 2009
  • 14533 Answers
SOURCE: I have a nice white Bemis toilet seat on which the
most hardware or home stores carry replacement hinges also online sites such as the hardwarestore.com sells replacement -larsen 2pc white hinge part 14-1039 $5.99 ace hardware,home depot, lowes, local stores
Posted on Jan 22, 2010
packrat1948
  • 528 Answers
SOURCE: What toilet seat hinge replaces
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
Posted on Mar 11, 2011
T am trying to remove a Bemis sattite toilet seat. How do I do it?
if you cannot get it to unseat you can take a hacksaw and carefully cut the bolts from under seat on top of toilet base easiest way to remove seat
Sep 11, 2015 | Bemis Home
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
WHERE CAN I GET REPLACEMENT SEAT AND COVER BUMPERS FOR MY BEMIS TOILET SEAT?
If the seat is a molded wood seat, you can usually get bumpers by contacting Bemis Customer Service, 920-467-4621. The bumpers on plastic seats are not replaceable because they are part of the seat.
Mar 26, 2011 | Bemis CHURCH Elongated White Slow Close...
What toilet seat hinge replaces Bemis elongated closed front toilet seat (plastic/not a bar/pair of hinges) and who sells? Can't believe Bemis does not support to proclaim hinges set in warm plastic...
Mar 11, 2011 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
Plastic coating is wearing on toilet seat can I buy something to recoat it.
It would be cheaper to buy a new toilet seat. Ijust bought one for ten dollars!!!
Jan 24, 2010 | Bemis 44BN Round Toilet Seat, White
Jan 22, 2010 | Bemis 200 Slow Regular Toilet Seat, White
Plastic hinge has a split in it causing wiggle
After looking at Bemis' website and finding out that the plastic hinges are not replaceable, I decided to return seat twhere i originally bought it since it's under warranty.
Thank you...
Dec 26, 2009 | Bemis Home
Aug 22, 2009 | Home
Home Logo
Top Bemis Home Experts
jdthefixer
john h
Are you a Bemis Home Expert? Answer questions, earn points and help others
